Home » Audio » Silicon Valley » LM3875
National Semiconductor Amp Modules [message #10204 is a reply to message #10203] Mon, 20 September 2004 16:53 Go to previous messageGo to previous message
Gnational is currently offline  Gnational
The entire amp circuit is on the module's IC substrate. The only external circuitry required is a power supply.
Beyond that, use the amp modules as suggested in the applications notes. In particular, refer to the external
components description section. There you will find specific guidelines for component values.
Previous Topic: DIY amp kits
Next Topic: I wish there had been more to fix!
Current Time: Mon Oct 05 08:55:41 CDT 2026
