Home » Audio » Speaker » Does room size alone determine which speaker is best?
Does room size alone determine which speaker is best? [message #99923] Mon, 16 November 2026 04:36 Go to next message
George is currently offline  George
I've always known that speakers are recommended generally based on the size of a room. A lot of people would always ask that bigger speakers are gotten for rooms with bigger spaces.
While that approach is great, I am of the opinion that there is more to it, like getting the maximum output, listening distance, placement flexibility, sensitivity, room acoustics, and bass extension. Considering these factors are good when we talk about how good a speaker can function in a given space.
So, what factors do you always consider when matching speakers to a room?
Do you begin with listening distance, room dimensions, bass extension, or something else? I would appreciate it if you shared what combinations work wonders for you.
Re: Does room size alone determine which speaker is best? [message #99929 is a reply to message #99923] Wed, 18 November 2026 18:18 Go to previous messageGo to next message
High sensitivity speakers like from this website did it for me. Plus I was going into the tube amplification route that historically at least are lower wattage output necessitating being paired with higher sensitivity speakers. My room is large enough and the speakers reflect that just by what the size was required of their design. I have a big rug in front of them to mitigate hardwood floors. And I have curtains too which I think tames all the ping pong effects of sound bouncing around the room.
I like them because they can easily fill the room without turning the volume high. Low distortion and articulate. They sound great with either tube or solid state amps.
Re: Does room size alone determine which speaker is best? [message #99938 is a reply to message #99929] Mon, 23 November 2026 20:15 Go to previous messageGo to next message
Hi, I give that a qualified maybe.  If the room is large then probably any type and size will probably do if they can produce the listening level desired.  If the room is small then you can get into problems.  I consider my room almost too small for the speakers I use.  The room is about 12 feet wide, 18 long and 9 might.  The speakers are on the width as there is a doorway in the long side.  I use Martin Logan ESLs backed up with a pair of Altec Lansing Voice of the theater (home version) used as subs.  I amplify all 4 separately with identical tube amps (for those in the know Oddwatt push-pull class A mid sized with KT120s run in rather low power at 62ma each).  20 watts per speaker is quite adequate to drive you out of the house.  I would not recommend ESLs in any room smaller they need space.  Best size would likely be about twice what I have.  Many modest sized floor standers and "book shelf" sized speakers would be fine in my room. Unfortunately the house came well before the speakers.
Re: Does room size alone determine which speaker is best? [message #99942 is a reply to message #99923] Wed, 25 November 2026 00:06 Go to previous message
Clint is currently offline  Clint
I've noticed in my studio that the room and listening distance can matter just as much as the speaker itself.  I would be recommending LP-6 V2 as a starting point because it's been fantastic since I got it.
Are you using them mainly for music enjoyment or for production?
Previous Topic: Replacing The Subwoofer
Current Time: Thu Nov 26 03:57:37 CST 2026
