| Does room size alone determine which speaker is best? [message #99923] |
Mon, 16 November 2026 04:36  |
George
Messages: 91 Registered: September 2025
Viscount |
I've always known that speakers are recommended generally based on the size of a room. A lot of people would always ask that bigger speakers are gotten for rooms with bigger spaces.
While that approach is great, I am of the opinion that there is more to it, like getting the maximum output, listening distance, placement flexibility, sensitivity, room acoustics, and bass extension. Considering these factors are good when we talk about how good a speaker can function in a given space.
So, what factors do you always consider when matching speakers to a room?
Do you begin with listening distance, room dimensions, bass extension, or something else? I would appreciate it if you shared what combinations work wonders for you.
| Re: Does room size alone determine which speaker is best? [message #99942 is a reply to message #99923] |
Wed, 25 November 2026 00:06  |
Clint
Messages: 68 Registered: December 2025
Viscount |
I've noticed in my studio that the room and listening distance can matter just as much as the speaker itself. I would be recommending LP-6 V2 as a starting point because it's been fantastic since I got it.
Are you using them mainly for music enjoyment or for production?
