| Is there still a practical reason to go for a vintage tube amplifier? [message #99918] |
Sun, 15 November 2026 00:21  |
Kurt
Messages: 42 Registered: December 2025
Baron |
Vintage tube amplifiers have a certain appeal that is difficult to explain to a person who's never listened or owned one before. I think the construction, the visible tubes, the transformers, and even the different designs make it hard to ignore.
I believe there are still great vintage models like Marantz 8B and Fisher 500C that still attract big interest in the market, but we know age comes with its own issues. Components can get worse, capacitors deserve attention, and an abandoned amplifier can turn out to be more expensive to restore.
I have also seen modern designs like the PrimaLuna Evo 400 offering some of the traditional tube experience with modern engineering and technical support. That makes me wonder
whether if vintage ones still offer anything special aside from the nostalgia feeling of owning an older gear.
If you've got both the vintage and modern tube amps, which one have you settled on for everyday use? What shaped your decisions on what to use more often?
| Re: Is there still a practical reason to go for a vintage tube amplifier? [message #99920 is a reply to message #99918] |
Sun, 15 November 2026 11:41   |
I grew up on solid state, and was very blessed to have started my "serious" hifi passion with a really good design, the Yamaha CR-1040. The engineers were very careful to set the gain stages so full-scale rotation of the volume knob was just below clipping with full-amplitude input.
To me, that's extremely important for solid-state amps. It's not a huge engineering exercise, but it is a requirement for distortion-free performance. If I run a solid state amplifier, I expect that. Because a solid state amplifier sucks if it gets past clipping in any gain stage.
A solid state amplifier used for high-fidelity must incorporate global negative feedback to compensate for the fact that the transistors used aren't pure signal multipliers. I've seen a few solid-state amps that were designed without global feedback, but I think it's a dubious practice since the devices used really need it.
Ironically, vacuum tubes are closer to being pure signal multipliers. So a simple single-ended amp can be made with tubes and the quality is good. Same thing for push-pull amps, especially when biased to provide a lot of overlap in conduction modes. These designs don't necessarily depend on global negative feedback. A smidge can be used, and some designers do that. But it becomes more of an "Nth degree" thing rather than a requirement.
| Re: Is there still a practical reason to go for a vintage tube amplifier? [message #99925 is a reply to message #99920] |
Mon, 16 November 2026 15:54  |
gofar99
Messages: 2063 Registered: May 2010 Location: Southern Arizona
Illuminati (5th Degree) |
Hi, many of the vintage amps are really excellent and command very high prices. If they were garbage (some are) then they would not be in demand. I agree with Wayne on the clipping on SS amps. Really horrible. I like class "A" amps and all my designs are 100% class "A" with nearly zero negative feedback. Just enough to insure high frequency above band stability.
