Home » Audio » Source » Does the turntable still make a huge difference in a vinyl setup?
Does the turntable still make a huge difference in a vinyl setup? [message #99908] Tue, 10 November 2026 12:01 Go to next message
Cole is currently offline  Cole
I would like to know if the turntable still makes the biggest difference in a vinyl setup. You know, I've seen a lot of people say that the turntable itself is the most important component in the setup while others claim that the phono stage and cartridge got a bigger say in how the final sound turns out.
Let's say someone is using a good Technics SL-1200GR2 with an Audio-Technica VM540ML cartridge, do you think upgrading the phono stage make a more noticeable difference instead of getting an expensive turntable?
I am also putting into consideration that some of this might be down to what someone likes to upgrade first. You know some would want  settings while other would want as much detail as necessary.
So, what is that component that you upgraded in your vinyl record that made a big difference? Was it down to personal choice or what was required to change at the time?
Re: Does the turntable still make a huge difference in a vinyl setup? [message #99914 is a reply to message #99908] Thu, 12 November 2026 18:57 Go to previous message
Rusty is currently online  Rusty
If you have the two items mentioned you're really well set. For me it was a turntable that kept the speed constant with no pitch variation. A Technics 1200 MK6 did it for me. I have several MM, an MI and an HOMC and LOMC cartridges. I don't find their subtle differences critical.
I've found for me that a good line stage preamp is more an improvement in the sound than the few phono preamps I've used. And lastly, the loudspeaker is the most important. High sensitivity from this website was the end of my wanderlust.
Previous Topic: Would you say CDs killed the idea of albums seen as a whole piece of work?
Current Time: Thu Nov 12 19:10:13 CST 2026
