| Is switching from carpets to hardwood floors actually worth it? [message #99406] |
Mon, 11 May 2026 10:44  |
Bercle
Messages: 88 Registered: December 2025
Viscount |
What has been your experience with hardwood floors in a listening room? What I currently have right now is carpet, and it seems it makes the room feel quiet and the music not sounding the way that I want it to sound. In the beginning, I felt it was fine since I didn't have to get echo, but I don't feel that satisfied and have been thinking of switching to hardwood floors.
Is there anyone who's tried using both? Do you think hardwood floors with good treatment are better than using just carpet, or should I keep managing this?
| Re: Is switching from carpets to hardwood floors actually worth it? [message #99440 is a reply to message #99406] |
Mon, 25 May 2026 20:18   |
Clint
Messages: 60 Registered: December 2025
Viscount |
I have been opportune to make use of both carpets and hardwood in the listening. For that reason, I get how you are feeling about the whole thing.
When I had carpet in the room, it brought about zero echo and a dead-quiet room, and the feeling was good at the beginning, but certain things weren't cool with it. The vocal sounded dull, for example, and the energy in the songs that I listened to weren't fantastic.
I would say that Hardwood is better because when I got them last four years, placing a think rug between the speakers and I, some absorption panels on the first reflection points and bass traps in the corners of the rooms made the songs sound far more better than when I made use of carpets.
So, I will always pick Hardwood because I like better sounds when I listen to songs in the listening room. You can stick to your carpets if you are pretty fine with calm sounds.
| Re: Is switching from carpets to hardwood floors actually worth it? [message #99507 is a reply to message #99440] |
Sat, 13 June 2026 13:11   |
Prince
Messages: 112 Registered: September 2025
Viscount |
Clint wrote on Mon, 25 May 2026 20:18I have been opportune to make use of both carpets and hardwood in the listening. For that reason, I get how you are feeling about the whole thing.
Anyone who is not so bothered about the sound quality of songs or movies that they are watching should get a carpet because that is quite affordable. However, I'd advise anyone keen on improve the sound quality of their music gears to switch to hardwood. The difference is certainly clear.
| Re: Is switching from carpets to hardwood floors actually worth it? [message #99890 is a reply to message #99857] |
Tue, 27 October 2026 23:48  |
Clint
Viscount |
gofar99 wrote on Sat, 10 October 2026 21:19Hi, a tricky subject. I have concrete floors. I found the best combination was to place a area rug between my listening position and the speakers and leave the rest alone. I have various other fixes like large stuffed furniture, some wall coverings and something that I originally thought might be bad....a high (9 foot that is slightly sloped to the side) popcorn ceiling. Since the main speakers are ESLs everything matters.
Hi mate, thank you for sharing your preference.
I feel that concrete floors can be tough, but your setup with just an area rug in the middle sounds smart and simple. I also like how you left the rest alone and used furniture plus the sloped ceiling, which is a good move.
Does the popcorn texture help soak up any harsh reflections for your ESLs, or does it mostly just stay out of the way?
Would appreciate a response concerning that.
