| Re: Tubes from Russia [message #99835 is a reply to message #95342] |
Thu, 01 October 2026 01:10   |
Kurt
Messages: 42 Registered: December 2025
Baron |
Hey man,
Looking back from 2026, yeah, the sanctions hit Russian tubes hard.
I run Tung-Sol and Sovtek tubes in my Evo 400 and Rogue Cronus. They’re still made at Reflector and sound excellent when you get a good matched set — sometimes better than old NOS. Reliability stays solid if the power supply is right and you don’t push them.
Getting them here has been patchy for years, though. Shipping, payments, and tariffs made stock uneven and prices higher.
I keep JJ tubes as my everyday ones now because they’re consistent. Chinese fill the gaps. I still buy Russian when a decent batch shows up because they work great in my amps, but I don’t count on them like before.
Demand for real tubes isn’t going away. Plenty of us still want that feel. Heat’s still an issue in summer, so I switched around, but the tubes keep going.
Is anyone still finding good Russian stock regularly?
| Re: Tubes from Russia [message #99907 is a reply to message #99838] |
Mon, 09 November 2026 01:15  |
positron
Messages: 165 Registered: May 2020
Master |
I have heard from others concerning problems with stability,
tubes cheery and/or arcing of russian output tubes. I
experienced problems myself near higher rated plate
dissipation levels.
I did some checking and found that the 1 grid is not gold
plated on some/many russian output tubes, so possible
thermal runaway problems can rise.
But even more important, the rods holding the grids (esp #2)
are aluminum, not copper. Excessive heating will cause aluminum
to warp, thus the dissipation of both plate and screen grid
needs to be limited. I am running 29 watts plate dissipation,
and no problems so far concerning run away etc.
Hope this helps in understanding the problems concerning
stability and ratings with at least some russian output
tubes.
pos
