Home » Audio » Group Build » DIY Panels
Re: DIY Panels [message #99809 is a reply to message #85831] Fri, 18 September 2026 01:22 Go to previous message
Hank is currently offline  Hank
I ran into the exact same problem when I put up DIY panels in my old row house. They quieted the room a little but the piano still carried outside because panels mostly soak up echo, not block sound from leaving.
I added more panels and sealed every gap around the doors and windows, which helped some more. For better results I later tried heavy curtains and a thick rug.
I’d keep what you built. They make the room nicer for your daughters and just layer on sealing next. That combo worked better for me than starting over.
Previous Topic: Kit vs. Finished Speakers
Next Topic: A New Ground
Current Time: Sun Nov 22 19:10:56 CST 2026
