| Looks Bad, Sounds Good [message #82875] |
Wed, 22 June 2016 04:15  |
Concorde
Messages: 155 Registered: December 2013
Master |
Have you ever had a system like this? It looks like it wouldn't put out good sound quality at all, but when you turn it on you get blown away.
| Re: Looks Bad, Sounds Good [message #84398 is a reply to message #82875] |
Tue, 24 January 2017 09:38   |
Hylo
Messages: 30 Registered: January 2017
Baron |
| Concorde wrote on Wed, 22 June 2016 04:15 | Have you ever had a system like this? It looks like it wouldn't put out good sound quality at all, but when you turn it on you get blown away.
| What, like my duct-tape special?
If you mean the kind of thing that looks like a bunch of roadies threw it together in five minutes, with mismatched brands, different finishes, taped connections, weird angles, and bass that makes your teeth hurt? I've seen a few. They don't last long, but hey, they aren't built to, just to sound good while they are running.
| Re: Looks Bad, Sounds Good [message #99776 is a reply to message #82875] |
Thu, 10 September 2026 00:08  |
Clint
Messages: 60 Registered: December 2025
Viscount |
I've got a couple of gears that didn't look that fantastic, but deliver quality when in use like the pair of used small monitors that I bought years back from a store down the street. Looking at them, you would discard it as not good because of how they looked.
I took my chance with them after the seller convinced me. The first time that I connected them for recording beats, the clarity was amazing. I had a nice session using them, and the mixes sounded good when I tested and ran it in my car.
That experience made me not always disregard what certain gears can do by mere looking at them. I still have the monitors and use it for minor projects.
