Home » Audio » Craftsmen » How Hard Is It?
How Hard Is It? [message #68681] Fri, 22 July 2011 12:01 Go to next message
How hard is it to build your own equipment? I'm sure it varies by type, but generally speaking, are you always tearing your hair out or is it fun and relaxing for you?
Re: How Hard Is It? [message #68684 is a reply to message #68681] Fri, 22 July 2011 15:10 Go to previous messageGo to next message
Depends on
1. Your personal interests
2. Your skill level
3. Your frustration tolerance level.
I personally will build speakers all day, do cross-overs when I have to, might consider wiring a tube amp, won't even consider a SS amp, particularly if surface mount components are involved.
Bob
Re: How Hard Is It? [message #68771 is a reply to message #68681] Thu, 28 July 2011 08:37 Go to previous messageGo to next message
Hmm, I can see frustration tolerance perhaps being a problem for me. Laughing Perhaps I should stick with just buying equipment.
Why are solid state amps out of the question for you?
Re: How Hard Is It? [message #68791 is a reply to message #68771] Sat, 30 July 2011 07:03 Go to previous messageGo to next message
Hi Bob, good to see ya here.
Nymeria, I've been known to fling a capacitor across the room in frustration, but I still keep trying to build electronics 'cause of the "I did it!" factor.
Speaker-building, well...I've been woodworking all my life and I have the basic techniques mostly under control. Still, with every new speaker project, I usually find a previously undiscovered way to screw up. But then, I get to exclaim..."I did it!"
Going from a buyer to a builder is like going from a listener to a player, very satisfying.
Re: How Hard Is It? [message #99769 is a reply to message #68681] Tue, 08 September 2026 12:53 Go to previous messageGo to next message
Hank is currently offline  Hank
Before we talk about the difficulty, it is important that we consider passion. How passionate are you when it comes to building customised sound gear? If you have that desire, you can do it without much hassle. It can only take some time.
Re: How Hard Is It? [message #99770 is a reply to message #99769] Tue, 08 September 2026 15:38 Go to previous messageGo to next message
Too true.  I agree with that.
Re: How Hard Is It? [message #99774 is a reply to message #99770] Wed, 09 September 2026 22:02 Go to previous message
I have been building stuff for a very long time.  I find it relaxing and challenging at the same time.  I always figure I can push the envelop further.  No matter what the build is the next one can surely be made better. A classic example is my first tube phono preamp.  It was 2008 and it hummed like all get out.  It could find an AC source faster than any meter I owned.  Certainly not what I had in mind.  Through several iterations it now is going to be really difficult to improve.  With a ruler flat response (with an inverse RIAA source) from about 8 HZ to about 75KHZ and a S/N of -94DBV it is stellar, but as recently as this morning I tested a few minor changes that might make it better (no changes as it turns out).  This shows the rewarding and challenging concepts well. More in regard to the topic, a few thing that were mentioned earlier matter.  I consider a basic knowledge the starting point on building anything.  You need an understanding of how things work.  You will gain more as you progress.  Second you need the tools to make it work. Next is a clear idea of what you are trying to do.  And the one I consider most important is the willingness to reach out to someone who can provide you guidance.  Many folks like those on this web site are glad to assist.  A great resource so use it. I get a goodly number of requests for assistance and am glad to help.  Sometimes it is my call that what they want to do is either impossible or at a really high skill level and if they were at that level they could certainly do it with out my help.I personally prefer tube based gear but do a fair amount of solid state stuff even a few speakers. One thing that I do usually believe in is that if you can buy something that does what you want to do for significantly less in cost, you really should consider buying it. Not everything on the market is junk.
Previous Topic: Where to get kits
Next Topic: Emma Repairs
Current Time: Mon Nov 02 14:14:25 CST 2026
