Home » Audio » Silicon Valley » Power FETs
Re: Power FETs [message #99729 is a reply to message #98057] Sat, 22 August 2026 21:51 Go to previous message
Hank is currently offline  Hank
The thing is that I've made use of N channel enhancement mosfets as a CSS a couple of times when I ran different projects. The last one that I did was when I constructed one for powering LEDs in a test circuit. It worked pretty well when I was able to fit the resistor value correctly.
The word of advice that I would give is for you to ensure that you make use of quality parts in your setup because there are chances that the  current will fluctuate sometimes. Another thing that I always did was watch the heat and match closely because not doing so can make a mess of the whole thing.
Aside from these minor issues,  I would say the N-channel enhancement MOSFETs does a good job for low-cost constant current and I've had a few successes using it in the past.
Previous Topic: What's your preferred solid-state amp now?
Next Topic: Thinking about the Vitus SS-103, is it worth the price?
Current Time: Sun Nov 08 15:14:04 CST 2026
