Home » Audio » Silicon Valley » What's the longest solid-state amp that you've owned?
What's the longest solid-state amp that you've owned? [message #99728] Sat, 22 August 2026 21:49 Go to next message
Hank is currently offline  Hank
In your experience of making use of solid state amps, which of the amps that you would say have delivered for the longest period?
I've had the boss katana 100 for a long time now and would say that the favourite amp that I've ever gotten with minimal issues over a period. Which one tops it for you?
Re: What's the longest solid-state amp that you've owned? [message #99731 is a reply to message #99728] Sun, 23 August 2026 08:26 Go to previous messageGo to next message
Since the late 80's. I can't remember what year I did a Hafler 220 kit that I still use today in hot weather. I have tube amps too. I've always like it's sound. Which is benefitted by a real good tube preamp.
Re: What's the longest solid-state amp that you've owned? [message #99732 is a reply to message #99731] Sun, 23 August 2026 11:30 Go to previous messageGo to next message
Hi. The longest and still in use running the PC audio and a turntable right now just above the monitor is a Marantz 1060 Console amp.  I bought it in 1969.  So 57 years.
Re: What's the longest solid-state amp that you've owned? [message #99826 is a reply to message #99732] Sat, 26 September 2026 02:34 Go to previous messageGo to next message
gofar99 wrote on Sun, 23 August 2026 11:30
Wow! It is lovely that the Marantz 1060 has been with you for 57 years. That's quite a long time, and it shows that the gear is good. My Boss Katana 100 has been nice, too, and that's what I've been using for a while now.
How does Marantz sound with your turntable and PC after all that time? Do you have any tips on keeping old amps being active for this long?
Re: What's the longest solid-state amp that you've owned? [message #99827 is a reply to message #99826] Sat, 26 September 2026 21:37 Go to previous messageGo to next message
Hi The amplifier sounds excellent.  They used really good components and built them to last.  The only thing I have needed to do was replace the power switch as the original got crunched.  Back then roughly 35 years ago they were easy to locate.  I think it was about $2.  Now things might be a bit more difficult.  I find that I have to exercise the switches about every 6-12 months as most never change in the settings.  I really like the amp and it mates well with the pair of Martin Logan motion 4's next to the monitor and a ML powered sub on the floor nearby.  When poking through the web on values of vintage gear this one kept showing up in the $1000 range.  It seems that is was among some of the last actually designed by Saul Marantz and built to spec in either Sunnyvale Ca or Japan.  The 1976 receiver (2250) is not built to the same standard as it was among the first built under the Superscope take over.  (my dates may be subject to question as that was a long time ago)  It sounds excellent also.  The third Marantz is a 2265B receiver.  Just slightly newer than the 2250.  Build is about the same.  This one is a world wide model and can run on pretty much any voltage.  Nice sound again, but the build is not all that great.  I have had trouble with that one.  It fried the speaker muting relay, had panel bulb issues and seemed more sensitive to needing the controls exercised.  Generally a nice unit, but not as well made.  Web values indicate the same thing you can get one supposedly refurbed for about $850.  BTW all the tube models are now out of reach by pure mortals.  Mega dollars.  Another thought.  With premium gear it is usually not necessary to re-cap them unless there is an indication of malfunction.  They were designed to last and even the  not so pretty builds of the 2250 and 2265 the components are top notch. You are more likely to screw something up than enhance the sound. Rolling Eyes
Re: What's the longest solid-state amp that you've owned? [message #99843 is a reply to message #99827] Sun, 04 October 2026 12:42 Go to previous messageGo to next message
gofar99 wrote on Sat, 26 September 2026 21:37
Thanks, mate for the tips. 57 years is pretty amazing. I like my Boss Katana 100, and it’s been very reliable for me, but 57 years is something else.
I also liked what you said about not recapping an old amp just because it’s old. If it’s working and sounding good, I guess there’s no good reason to mess with it.
I’ll remember the thing about working the switches now and then, too. That’s something I probably wouldn’t have thought about.
That Marantz 1060 sounds like a real keeper. Do you still prefer the sound of it over most newer amps you’ve tried?
Re: What's the longest solid-state amp that you've owned? [message #99848 is a reply to message #99843] Tue, 06 October 2026 21:32 Go to previous message
Hi As a SS amp generally yes.  But I design ans build my own tube gear and I much prefar the sound.A picture of my current system.  There are 4 Oddblocks on either side of the tape recorder.  On the top right shelf with a wood case is one of my tube phono preamps.  Just below the Empire turntable under it and not really visible is my line stage preamp.  All my designs and have been posted eleswhere on the web (mostly in diyaudioprojects.com).  The tall speakers are Martin Logan ESLs.  Behind them in the corners are Altec Lansing home versions of the voice of the theater.  I use only the low frequency drivers as subs (awesome).  The second photo is of a stereo version of the amps with a modular SS preamp. Most of the projects have been published in Audio Express./forum/index.php?t=getfile&id=3616&private=0[img]/forum/index.php?t=getfile&id=3617&private=0[/img]
Previous Topic: Thinking about the Vitus SS-103, is it worth the price?
Current Time: Mon Nov 23 02:18:15 CST 2026
