Home » Sponsored » Pi Speakers » 4pi: Cabinetmaker's build
Re: 4pi: Cabinetmaker's build [message #99482 is a reply to message #99481] Thu, 04 June 2026 16:01 Go to previous messageGo to next message
It's easy to overlook polarity, especially on that model.  The 2226H is positive black, as is the DE250.  But not the Omega 15A or the PSD2002.  It's almost like a trick or a practical joke. https://audioroundtable.com/images/lil_laughie.gif
I like to lay the cabinets on their backs to remove all the screws.  Then use a plastic trim tool - like is commonly used by mechanics when removing dash or door trim - to pry up one side of the driver.  That protects the wood.  Sometimes you can use a bit of cloth underneath the tool to further protect the wood.
If you feel brave, leave the cabinet standing but tilted back 20 to 30 degrees.  Remove all the screws but one in the bottom.  Push the edge of the driver - holding it in position - while removing that last screw.  Then slowly reduce pressure holding the driver in, allowing it to slide out.
Re: 4pi: Cabinetmaker's build [message #99483 is a reply to message #99291] Thu, 04 June 2026 20:44 Go to previous messageGo to next message
dustboy is currently offline  dustboy
Okay...Is it possible that the red on the DE250's is actually positive? I played with the polarities a bit and with the woofers black to + and tweeters red to +, the speakers sprang to life! I am in the room with Arne Domnerus right now!!
Re: 4pi: Cabinetmaker's build [message #99484 is a reply to message #99483] Fri, 05 June 2026 09:20 Go to previous messageGo to next message
I doubt it very seriously but you can easily verify with acoustic measurements.  If the compression driver is wired backwards, there will be a big dip in the crossover region when measured on-axis.  The vertical nulls won't be at +/-20 degrees either.
And just to clarify, on the compression driver it isn't so much the traditional meaning - whether the red/positive lead creates positive pressure - as it is that the four Pi design requires the DE250-8 to be wired with the black lead connected to positive.
Re: 4pi: Cabinetmaker's build [message #99497 is a reply to message #99291] Tue, 09 June 2026 12:45 Go to previous messageGo to next message
I'll work on getting a test mic. For now, my ears say the polarities are correct.
My ongoing goal with my hifi system is to get as close as possible to having live music in my home, and the 4pi's have the magic I was looking for. In fact this sound is better than a lot of venues I've been to.
One question, any ideas on how to decouple the speakers from the wood floor? The spot where I want to place them is not covered by the rug, but I have noticed the bass is much cleaner when they are standing on the rug.
Re: 4pi: Cabinetmaker's build [message #99498 is a reply to message #99497] Tue, 09 June 2026 13:14 Go to previous messageGo to next message
Some people like to use spikes.  Their goal is to firmly "attach" the loudspeaker to the floor, using the weight of the cabinet to "nail" it to the floor by having such a small contact point.  The idea is to make the cabinet as steady and immovable as possible.
Another approach goes exactly the opposite, isolating the speakers from the floor.  Most use carpeting as you describe, or rubber feet. I prefer this method and always put rubber feet under my loudspeaker cabinets between them and any stands and place the stands on rubber mats or on carpets.
Re: 4pi: Cabinetmaker's build [message #99500 is a reply to message #99291] Tue, 09 June 2026 18:43 Go to previous messageGo to next message
Your local plumbing supply likely has small squares that have cork in the middle and rubber on the top and bottom.  They are used to keep the vibrations from heaters and air conditioners from transmitting their noise and vibrations into floors.   They work great under speakers.
They are very cheap but do tend to smell like a rubber factory when new.  A week or two out on the back porch generally makes them more acceptable.
They tend to be available in 2" squares and 4" squares.  You can likely get a bunch of them for $10 or $20.
Re: 4pi: Cabinetmaker's build [message #99504 is a reply to message #99500] Wed, 10 June 2026 09:50 Go to previous messageGo to next message
Good tip, thanks!
Re: 4pi: Cabinetmaker's build [message #99562 is a reply to message #99291] Tue, 07 July 2026 09:21 Go to previous messageGo to next message
I picked up a Dayton Audio iMM-6C calibrated mic and bought the Audio Tools app. I can get pink noise but don't see a way to measure with a sweep. Is there a tutorial somewhere on how to use this setup for measuring frequency response?
Re: 4pi: Cabinetmaker's build [message #99563 is a reply to message #99562] Tue, 07 July 2026 09:42 Go to previous message
I don't use that application - I use WTPro for development and LMS for publishing - but I will say that there should be a way to choose the source signal.  Some common test source signals are sine sweep, stepped sine, log sine (chirp), noise, MLS and TDS.
Also note that many systems offer gating for pseudo-anechoic measurements.  This allows you to make measurements indoors, because you can configure the system to only sample for a short (gated) period.  This prevents reflections from interfering with the measurement, but it also limits measurement of low frequencies.  It's great for checking the crossover region though, which is often useful during development.
Previous Topic: 4Pi plans
Next Topic: Pi Speakers FAQ
Current Time: Tue Jul 07 10:44:22 CDT 2026
