Home » Audio » Speaker » What speakers do you own right now?
Re: What speakers do you own right now? [message #99550 is a reply to message #99542] Thu, 02 July 2026 19:05 Go to previous messageGo to next message
I love the looks of your listening room!
gofar99 wrote on Tue, 30 June 2026 21:10
Hi I have a pair of Martin Logan ESLs for the mains and a pair of vintage Altec Lansing VOTs (voice of the theater home models) for subs.  The obvious issue with VOTs is size.  Even the home version is about 205 liters.  I did adjust the response a bit for more bottom end as they only crossover at 60HZ.  The MLs are a different breed altogether.  First they reflect rearward the same amount of sound as the direct mode. Everything matters. You need a pretty good sized room.  Too small and they will never sound right.  Next the dimensions must not be a box.  My room is 12 feet wide,17 long and has a slightly sloped ceiling.  It has popcorn stucco on the ceiling as well.  The speakers can not be placed in a corner or near any wall.  Mine are 4 feet from the rear wall and about 3.5 from either side.  Slightly toed in at about 20 degrees and tilted rearward about 10 degrees.  When done properly they completely envelop you with sound.  In order to get such a wide sound stage you lose a slight bit of directionality.IMO a really good trade off.  They are unforgiving, if you feed them crap it will sound that way.  Good source material is a must.  They are highly accurate and have a very fast response.  Other ESLs generally share the traits.  I can never go back to non-ESLs. /forum/index.php?t=getfile&id=3595&private=0
Re: What speakers do you own right now? [message #99657 is a reply to message #86713] Thu, 06 August 2026 16:10 Go to previous messageGo to next message
I'm currently using a pair of Tekton Lores with the Audex Gold tweeter. A lively and dynamic speaker considering their low cost ($1100 including shipping in continental USA.)
I was using some EV 12TRXC coaxial drivers in 4.5 cu ft enclosures I built. Very heavy built. The mids and lows were great down to 70Hz, but dropped off quickly below that. Highs above 3K tended to be a bit harsh and dropped off above about 14K. They took up a lot of real estate in my small living room, so they now sit stored in my shed. They'd make great party speakers, though. At 99dB or 100dB sensitivity, a 50 watt amp would play LOUD!
Dave
Re: What speakers do you own right now? [message #99659 is a reply to message #99657] Fri, 07 August 2026 07:16 Go to previous message
Hi Dave,
I remember your posts from back in the Hawthorne Audio days. It was great following all the goings on in that forum as a lot of folks were discovering open baffle speakers. Learned a lot trying to absorb what was happening there.
Nice to see you back online.
Barry
Previous Topic: Speakers In Robots
Next Topic: How many subwoofers
Current Time: Mon Oct 26 13:50:30 CDT 2026
