Home » Audio » Pro Sound » Is room treatment a must for bedroom producers?
Re: Is room treatment a must for bedroom producers? [message #99537 is a reply to message #99516] Sat, 27 June 2026 01:39 Go to previous messageGo to previous message
Clint is currently offline  Clint
George wrote on Thu, 18 June 2026 08:45
Clint wrote on Mon, 15 June 2026 14:58
Wayne Parham wrote on Thu, 28 May 2026 16:29
It totally depends on the room and what you're lookin' for.
The room has a major impact on sound - there's no doubt about that.
So if you want to hear the source and not the room, you'll need to do some work.
But if you know your room - especially if you're on a budget - and if its flaws aren't glaring, you can probably do a budget setup and be fine.
Glaring flaws are things like all hard surfaces like concrete or tile, especially in a small space.  That's hard to work with 'cause it will over-emphasize certain sounds and make you want to mix 'em to "correct."  Playback in another environment - the sound is way off.
One thing that always helps - mount the speakers flush with the front wall and make your listening spot far away from the rear and side walls.  If you can't sit far from walls, cover them with acoustic wedges, largest you can get.  If you can't mount the speakers flush to the wall, pull 'em away from the front wall and/or use flanking subs.
That's right. I'm thankful for the nice advice.  I believe the hard walls in my bedroom must have been the reason songs sound better in headphones while I am inside but sound differently when I play them in the car.
I guess I will have to rearrange the monitors in my room away from the wall first and see how it goes. I will also work on getting some affordable acoustic panels for the reflection points.
I will test it on my next mix and let you know how it is going.
You are making the right move with the decision to move the monitors away from the wall.
As for the acoustics panels, I would recommend ATS panels or go for the Auralex Studiofoam Wedgies, which is what most of the studios that I've seen here use.
I think starting with 5 panels at mirror points is ideal. That's depends on the size of your room because if the room is bigger, you might need like 6 panels for a start.
Thanks, mate, for the suggestion that you made about moving my monitors.
I also appreciate you for the recommendation of the type of acoustic panels that I should get. I think I will have to go with the ATS panels because it is what I feel should suit my room, which is pretty small. It is also quite affordable and doesn't stress me much when it comes to fitting it in my room.
As regards whether I should start with five panels, I am of the opinion that I go with four panels because that will give me an opportunity to see how it sounds first before making a decision on whether to add more. The reason is because of how small my room is.
So, do you have any suggestions on how I should place the acoustic panel when I get them?
Previous Topic: Software to visualize sound waves
Next Topic: The most complex musical instrument
Current Time: Fri Nov 27 11:17:53 CST 2026
