Home » Audio » Thermionic Emissions » What are the common issues that you've experienced with using different tube amps?
What are the common issues that you've experienced with using different tube amps? [message #99486] Fri, 05 June 2026 13:20 Go to next message
Kurt is currently offline  Kurt
I would like to know various challenges that some of us have had while using different tube amps. Currently, I make use of Evo 400, Mclntosh MA352 hybrid, and the Rogue Audio Cronus Magnum III.
I am the type that likes having different options when it comes to vacuum tube amps, but I've experienced different challenges while using these amps. For example, I always feel an increase in heat in the room when I switch from Rogue to Evo 400. That meant that I am always careful of the one to use depending on weather conditions.
So, I would like to know if anyone here run multiple tube amps and what issues you've encountered while using them?
Is there a good tip on how to manage heat, and how do you get along with managing running multiple amps?
Re: What are the common issues that you've experienced with using different tube amps? [message #99487 is a reply to message #99486] Fri, 05 June 2026 14:23 Go to previous messageGo to next message
I've only used one tube amp. But they're monoblocks. And they're OTL's, so the issue with heat in inherent with that topology. Though mitigated a good deal with the design I've used for about 20 years. But I simply don't use them in the summer. Why fight the electric bill with the AC. So I switch to my venerable old Hafler 220 I've used for 40 years. I do keep the tube amps on top of the gear cabinet. Unobstructed from anything
Re: What are the common issues that you've experienced with using different tube amps? [message #99505 is a reply to message #99486] Wed, 10 June 2026 13:38 Go to previous messageGo to next message
Hank is currently offline  Hank
I truly understand how you feel with the heat that comes with tube amps. In fact, that was the main reason that I switched from using them years ago to focus on solid-state amps.
I was never comfortable in my room because of the heat till I got a small fan that was always on when I was using the tubes. So, maybe I suggest you get a fan that you can keep in the room that can make the room cooler. I don't bother about those issues anymore because I run solid-state amps, and they give less drama, unlike tubes.
Re: What are the common issues that you've experienced with using different tube amps? [message #99510 is a reply to message #99505] Mon, 15 June 2026 14:48 Go to previous messageGo to next message
Well I dunno. I feel like I get the best of both with tube & SS amps. As mentioned, I run the tube amps in cooler weather, so the heat isn't a problem then. Their like space heaters in a way. A friend of mine jokes that I could use them with a rotisserie above them. And then in summer months its the SS amp. The Hafler I have does tend to run warm if I use it a while. But not like the tube amps. I like the change up with certain aspects of the sound scape from either of the two types of amplifiers too.
Re: What are the common issues that you've experienced with using different tube amps? [message #99512 is a reply to message #99510] Mon, 15 June 2026 15:39 Go to previous messageGo to next message
That is such a cool idea - Seasonal amplifier tasting - I love it!
Re: What are the common issues that you've experienced with using different tube amps? [message #99515 is a reply to message #99510] Tue, 16 June 2026 23:53 Go to previous messageGo to next message
Rusty wrote on Mon, 15 June 2026 14:48
Just maybe this is why I am never comfortable with tube amps during the summer period. The weather is already hot and consistent use of tube amps especially the Evo 400 worsen the heat in the room. I agree that I should find that balance between using ss amps and tube amps, but it is never easy since I am a big fan of tube amps.
Re: What are the common issues that you've experienced with using different tube amps? [message #99541 is a reply to message #99515] Tue, 30 June 2026 20:46 Go to previous messageGo to next message
Hi, I understand heat...it what AC is for as it is usually pretty warm in Arizona anyhow.  I have presently a quad of KT120 mono blocks powering my system.  Yes they do get warm.  The photo is from a while back but I think you will get the idea./forum/index.php?t=getfile&id=3594&private=0
Re: What are the common issues that you've experienced with using different tube amps? [message #99553 is a reply to message #99510] Sat, 04 July 2026 00:30 Go to previous message
Oh well, this seems like what I would have to do. Use more of tube amps when the snows are out and not during the summer. I sense that is better and more convenient.
Previous Topic: Tube amps on PC.
Next Topic: Popular myths about tube amps
Current Time: Sat Jul 25 19:03:01 CDT 2026
