Home » Audio » Room Acoustics » Is switching from carpets to hardwood floors actually worth it?
Re: Is switching from carpets to hardwood floors actually worth it? [message #99507 is a reply to message #99440] Sat, 13 June 2026 13:11 Go to previous messageGo to previous message
Prince is currently offline  Prince
Clint wrote on Mon, 25 May 2026 20:18
I have been opportune to make use of both carpets and hardwood in the listening. For that reason, I get how you are feeling about the whole thing.
When I had carpet in the room, it brought about zero echo and a dead-quiet room, and the feeling was good at the beginning, but certain things weren't cool with it. The vocal sounded dull, for example, and the energy in the songs that I listened to weren't fantastic.
I would say that Hardwood is better because when I got them last four years, placing a think rug between the speakers and I, some absorption panels on the first reflection points and bass traps in the corners of the rooms made the songs sound far more better than when I made use of carpets.
So, I will always pick Hardwood because I like better sounds when I listen to songs in the listening room. You can stick to your carpets if you are pretty fine with calm sounds.
Anyone who is not so bothered about the sound quality of songs or movies that they are watching should get a carpet because that is quite affordable. However, I'd advise anyone keen on improve the sound quality of their music gears to switch to hardwood. The difference is certainly clear.
Previous Topic: Room Mode Calculator
Current Time: Wed Nov 18 03:10:36 CST 2026
