Home » Audio » Thermionic Emissions » What are the common issues that you've experienced with using different tube amps?
What are the common issues that you've experienced with using different tube amps? [message #99486] Fri, 05 June 2026 13:20 Go to previous message
Kurt is currently offline  Kurt
I would like to know various challenges that some of us have had while using different tube amps. Currently, I make use of Evo 400, Mclntosh MA352 hybrid, and the Rogue Audio Cronus Magnum III.
I am the type that likes having different options when it comes to vacuum tube amps, but I've experienced different challenges while using these amps. For example, I always feel an increase in heat in the room when I switch from Rogue to Evo 400. That meant that I am always careful of the one to use depending on weather conditions.
So, I would like to know if anyone here run multiple tube amps and what issues you've encountered while using them?
Is there a good tip on how to manage heat, and how do you get along with managing running multiple amps?
Previous Topic: Popular myths about tube amps
Next Topic: Buying Amps on eBay
Current Time: Fri Oct 23 19:53:33 CDT 2026
