Home » Audio » Home Theater » Improving the home theater
Improving the home theater [message #89520] Wed, 09 January 2019 01:57 Go to next message
At times when I am at home, I almost feel like I should be getting more from the system. I actually feel like the reason for this is because I have used a combination of old and new speakers. Which is the best way to match such speakers?
Re: Improving the home theater [message #89524 is a reply to message #89520] Wed, 09 January 2019 03:45 Go to previous messageGo to next message
Having a combination of old and new speakers can be a tricky affair, and requires a good technique of matching them, so as to get the deserved sound experience. It may also be the right time to consider upgrading the subwoofer.
Re: Improving the home theater [message #89788 is a reply to message #89524] Mon, 11 February 2019 09:46 Go to previous messageGo to next message
Porter is currently offline  Porter
Have you considered getting a soundbar? Adding a soundbar to your home theater system is one of the easiest and most affordable things you can do to improve your audio experience in my opinion.
Re: Improving the home theater [message #89792 is a reply to message #89788] Mon, 11 February 2019 13:17 Go to previous messageGo to next message
Porter wrote on Mon, 11 February 2019 09:46
I stand corrected but from what I have heard, it is not advisable to have both a soundbar and home theater. The latter is often the cheaper and less bulky alternative.
Re: Improving the home theater [message #89808 is a reply to message #89792] Tue, 12 February 2019 14:07 Go to previous messageGo to next message
Mamoss, I know you weren't asking me specifically, but I believe you can hook up a passive soundbar to your home theater receiver and get great sound. Well, you can hook up an active soundbar to your home theater system too, but I believe the two amplifiers might interfere with each other. I'm not sure a soundbar is the best option. Home theater systems are better at creating an immersive experience. It also might be cheaper to just replace the speakers that aren't working well.
Re: Improving the home theater [message #89816 is a reply to message #89808] Wed, 13 February 2019 02:17 Go to previous messageGo to next message
Strum Drum wrote on Tue, 12 February 2019 14:07
Ooh yes and this makes sense because it is much easier and simpler to replace the old problematic speakers. I don't know much about the soundbar option but it looks like a tenable idea.
Re: Improving the home theater [message #89880 is a reply to message #89520] Sun, 03 March 2019 22:02 Go to previous messageGo to next message
TheWanderer is currently offline  TheWanderer
From what I've read, you can certainly mix old and new speakers. You just have to position them correctly to get the most bang for your buck.
Re: Improving the home theater [message #99442 is a reply to message #89520] Wed, 27 May 2026 12:52 Go to previous message
Prince is currently offline  Prince
There are other factors that you might consider, such as room treatment, which many neglect. The type of curtains that you use at home may affect the quality of sound that you get from your speakers while playing them on the home theater. The use of old and new speakers is not a major factor unless you are having a feeling that the old speakers are not functioning as expected.
Previous Topic: Need help with choosing 5.1ch speakers for Home-theater
Next Topic: What's your preferred speaker for your home theatre device?
Current Time: Thu Aug 20 04:13:18 CDT 2026
