Home » Audio » Room Acoustics » Is switching from carpets to hardwood floors actually worth it?
Is switching from carpets to hardwood floors actually worth it? [message #99406] Mon, 11 May 2026 10:44 Go to next message
Bercle is currently offline  Bercle
What has been your experience with hardwood floors in a listening room? What I currently have right now is carpet, and it seems it makes the room feel quiet and the music not sounding the way that I want it to sound. In the beginning, I felt it was fine since I didn't have to get echo, but I don't feel that satisfied and have been thinking of switching to hardwood floors.
Is there anyone who's tried using both? Do you think hardwood floors with good treatment are better than using just carpet, or should I keep managing this?
Re: Is switching from carpets to hardwood floors actually worth it? [message #99409 is a reply to message #99406] Mon, 11 May 2026 11:52 Go to previous messageGo to next message
Hi,  This something Wayne should comment on as he has considerable experience in that area. My simple take is the hardness or softness of a room relates to how any particular speaker will sound.  I have what would be a mostly soft room.  Carpets, furniture, bookcases and acoustic stuff on the ceiling.  This in my case is required because I use electrostatic speakers that are bi-dimensional.  They rely on controlled back sounds.  More conventional speakers are not usually as demanding in that area, but will still depend on room resonances and reflections.  I hope this helps.
Re: Is switching from carpets to hardwood floors actually worth it? [message #99410 is a reply to message #99409] Mon, 11 May 2026 12:57 Go to previous messageGo to next message
Hardwood floors are beautiful, but acoustically difficult.  Same with tile, stone or concrete.  These kinds of surfaces are very reflective at all frequencies, which makes for an unnatural-sounding floor bounce.
If you want to make a listening room out of a room with hardwood floors, it's best to have a large rug between the listening area and the speakers.  That will at least reduce the high-frequency "slap" reflection.
Re: Is switching from carpets to hardwood floors actually worth it? [message #99413 is a reply to message #99410] Fri, 15 May 2026 00:26 Go to previous messageGo to next message
George is currently offline  George
Hi, Bercle
Just as Wayne said above, there is more to do if you are moving from carpets to hardwood floors. I've been there, and I know that using just hardwood floors won't give you the very best in terms of sound quality.
Re: Is switching from carpets to hardwood floors actually worth it? [message #99440 is a reply to message #99406] Mon, 25 May 2026 20:18 Go to previous messageGo to next message
Clint is currently offline  Clint
I have been opportune to make use of both carpets and hardwood in the listening. For that reason, I get how you are feeling about the whole thing.
When I had carpet in the room, it brought about zero echo and a dead-quiet room, and the feeling was good at the beginning, but certain things weren't cool with it. The vocal sounded dull, for example, and the energy in the songs that I listened to weren't fantastic.
I would say that Hardwood is better because when I got them last four years, placing a think rug between the speakers and I, some absorption panels on the first reflection points and bass traps in the corners of the rooms made the songs sound far more better than when I made use of carpets.
So, I will always pick Hardwood because I like better sounds when I listen to songs in the listening room. You can stick to your carpets if you are pretty fine with calm sounds.
Re: Is switching from carpets to hardwood floors actually worth it? [message #99507 is a reply to message #99440] Sat, 13 June 2026 13:11 Go to previous message
Prince is currently offline  Prince
Clint wrote on Mon, 25 May 2026 20:18
Anyone who is not so bothered about the sound quality of songs or movies that they are watching should get a carpet because that is quite affordable. However, I'd advise anyone keen on improve the sound quality of their music gears to switch to hardwood. The difference is certainly clear.
Previous Topic: Biggest waste of money?
Current Time: Sun Jul 05 03:25:31 CDT 2026
