Home » Audio » Pro Sound » Should I blow the budget on getting expensive cables? (Does it improve sound production?)
Should I blow the budget on getting expensive cables? [message #99355] Thu, 16 April 2026 23:54 Go to next message
Clint is currently offline  Clint
I've been wondering if those expensive cables affect sound production in a way that the normal cables can't? I've seen some ads concerning those expensive cables, and I am considering blowing my budget to get those.
Do you think it is a wise idea to do so? What has been your experience with using expensive cables? Is there a big difference between them and the normal ones?
Re: Should I blow the budget on getting expensive cables? [message #99370 is a reply to message #99355] Sun, 26 April 2026 14:27 Go to previous messageGo to next message
Hank is currently offline  Hank
See, I've got to be honest with you and speaking from experience, using cheap, well-built cables sound just neat and dynamic.
So, using an expensive cables rarely make any big upgrade in sound quality. The big differences are noticed with upgrades on amps, speakers and in some cases, room treatments.
For that reason, I won't advise that you spend above your budget getting expensive cables when you can spend that on upgrading the speakers, for example.
Re: Should I blow the budget on getting expensive cables? [message #99390 is a reply to message #99370] Mon, 04 May 2026 10:06 Go to previous messageGo to next message
Hank wrote on Sun, 26 April 2026 14:27
Thank you for your input. I will be reconsidering my plans of changing the cables to an expensive one. Possibly, I should work on making upgrades on the amps that I use at the studio because it's been a long time overdue!
Re: Should I blow the budget on getting expensive cables? [message #99391 is a reply to message #99390] Tue, 05 May 2026 08:52 Go to previous messageGo to next message
I agree.  Good cables aren't expensive.  This is the description of a good quality cable:  Quality insulator of uniform thickness and pure copper with uniform strands terminated at each end by good connectors.  Everything needed to achieve that is fairly inexpensive.
Re: Should I blow the budget on getting expensive cables? [message #99393 is a reply to message #99355] Tue, 05 May 2026 23:33 Go to previous messageGo to next message
Bercle is currently offline  Bercle
I understand that many might be leaning towards the direction of cables, not having a major impact on sound quality, which I won't dispute that much. My take is that when you spend enough to get quality cables at a higher cost, there are chances that it will last longer than the normal cables.
This consideration is what some don't look at as the focus is always on the end part. I can't imagine changing cable wires every seven months when I can get one, which is going to last for two years or more.
Re: Should I blow the budget on getting expensive cables? [message #99417 is a reply to message #99355] Mon, 18 May 2026 00:13 Go to previous messageGo to next message
George is currently offline  George
Aside from the aesthetic designs, I can't pick a thing that makes an expensive cable better than a normal quality cable. I mean there is no guarantees that you will get extra benefits from buying an expensive one.
Re: Should I blow the budget on getting expensive cables? [message #99436 is a reply to message #99393] Sat, 23 May 2026 23:57 Go to previous messageGo to next message
Prince is currently offline  Prince
Bercle wrote on Tue, 05 May 2026 23:33
I don't necessarily agree that I need to spend heavily before I can get cable wires that can last longer. Once I can find out affordable ones that are built better in terms of using solid metal connectors and thick wires in making it, I am pretty sure that it can last long and even more than the one you spent more money getting.
Some of these expensive ones are like that because of the brand and not necessarily about being far better than the less popular cheaper ones that were built well.
I don't also agree that there is a difference even in the sound quality of a setup done with an affordable wire that is well built and an expensive one that costs more.
Re: Should I blow the budget on getting expensive cables? [message #99455 is a reply to message #99436] Thu, 28 May 2026 23:45 Go to previous message
Prince wrote on Sat, 23 May 2026 23:57
You are totally correct. I believe that the bigger problem is mainly on getting an affordable one that was built well. Possibly, that is the reason a lot of people focus on buying the popular ones even when they are pricey.
Previous Topic: Best Headphones?
Next Topic: Software to visualize sound waves
Current Time: Tue Aug 04 23:35:21 CDT 2026
