Home » Audio » Source » Ordered a Schiit Mimir DAC (Will test)
Re: Ordered a Schiit Mimir DAC [message #99344 is a reply to message #99334] Mon, 13 April 2026 15:49 Go to previous messageGo to previous message
Wayne Parham wrote on Wed, 08 April 2026 16:09
What capacitors did you replace, specifically?
Were there electrolytics in the power supply?  Or perhaps ceramic, tantalum or electrolytic caps in the analog end of the signal path?
Or were they polypropylene or polystyrene caps, but you changed brands?
Are you into oil-filled caps?
Just curious what you swapped and what you like best.
Hi All,
Nothing is labeled, except chips, and the traces are hidden from
view, so I installed a couple of better quality audio grade Nichicon
capacitors in the power supply for the single ended op amp.
Other caps are mainly digital and main supply before regulators etc.
No poly caps and cost of such would be a grand or more, plus external
chassis.
The caps I used are no longer manufactured or sold, and were never
manufactured in large enough ufd/voltage values.
The caps I tested and use now for other projects are
Mundorf aluminum in oil. Larger values sound great,
smaller values, like other brands tested, will sound more or less
accurate, and may need a tweak I can do to the copper/gold plated
jacks.
Important: Never believe websites that claim to test and rate
capacitors. They have No idea of how to correctly run a test
and I have yet to find results that are even close to accurate.
The analog appears to be dc coupled, Burr Brown Audio chip which has
very good gain bandwidth product.
I am thinking of offering an upgrade to the Mimir single ended outputs,
pigtail analog output jacks and upgrade caps. I only use all
copper/gold plated jacks. I need to tweak the jacks no matter the brand.
If this is not allowable, I will delete this offering and offer my apology.
cheers
pos
Previous Topic: Oiling Turntable Bearings
Next Topic: Digital looks so simple, sometimes I miss the vinyl ritual
Current Time: Thu Nov 12 22:41:58 CST 2026
