Home » Audio » Source » Ordered a Schiit Mimir DAC (Will test)
| Re: Ordered a Schiit Mimir DAC [message #99290 is a reply to message #99283] |
Mon, 16 March 2026 19:35   |
positron
Messages: 165 Registered: May 2020
Master |
Wayne Parham wrote on Fri, 13 March 2026 12:30
That's really awesome!
I've heard nothing but good things about that company and its products.
Hi Wayne,
Yes, absolutely. I should have previously posted another thought I
have been mulling over.
Since the recording equipment is half the
electronics, how do I know how close to butting up against
the absolute maximum sonic quality of the recording components?
I think I am quite close after adding the all copper single
ended output jacks with Jenalabs wire increased naturalness
a little, but noticeable. Interestingly,
I just made another upgrade, and the sound improvement was not
as apparent. I think I am really really close now, as the sonic
improvement, naturalness should have been larger.
I don't think I am going to try anything else, at least for awhile.
cheers
pos
| Re: Ordered a Schiit Mimir DAC [message #99330 is a reply to message #99290] |
Tue, 07 April 2026 19:25   |
positron
Master |
positron wrote on Mon, 16 March 2026 19:35Wayne Parham wrote on Fri, 13 March 2026 12:30
Hi Wayne,
cheers
pos
I guess the definition "for a while" was not too long for me. :)
I am working with the power supply and improved the sonics,
slightly; cleaner across the entire audio band. Higher quality
audio grade capacitors, voltage rating etc, makes a difference.
Cheers
pos
| Re: Ordered a Schiit Mimir DAC [message #99344 is a reply to message #99334] |
Mon, 13 April 2026 15:49   |
positron
Master |
Wayne Parham wrote on Wed, 08 April 2026 16:09
What capacitors did you replace, specifically?
Were there electrolytics in the power supply? Or perhaps ceramic, tantalum or electrolytic caps in the analog end of the signal path?
Or were they polypropylene or polystyrene caps, but you changed brands?
Are you into oil-filled caps?
Just curious what you swapped and what you like best.
Hi All,
Nothing is labeled, except chips, and the traces are hidden from
view, so I installed a couple of better quality audio grade Nichicon
capacitors in the power supply for the single ended op amp.
Other caps are mainly digital and main supply before regulators etc.
No poly caps and cost of such would be a grand or more, plus external
chassis.
The caps I used are no longer manufactured or sold, and were never
manufactured in large enough ufd/voltage values.
The caps I tested and use now for other projects are
Mundorf aluminum in oil. Larger values sound great,
smaller values, like other brands tested, will sound more or less
accurate, and may need a tweak I can do to the copper/gold plated
jacks.
Important: Never believe websites that claim to test and rate
capacitors. They have No idea of how to correctly run a test
and I have yet to find results that are even close to accurate.
The analog appears to be dc coupled, Burr Brown Audio chip which has
very good gain bandwidth product.
I am thinking of offering an upgrade to the Mimir single ended outputs,
pigtail analog output jacks and upgrade caps. I only use all
copper/gold plated jacks. I need to tweak the jacks no matter the brand.
If this is not allowable, I will delete this offering and offer my apology.
cheers
pos
| Re: Ordered a Schiit Mimir DAC [message #99347 is a reply to message #99345] |
Tue, 14 April 2026 16:07  |
positron
Master |
Wayne Parham wrote on Tue, 14 April 2026 08:11
Very cool, thanks for letting us know.
I've upgraded electrolytic caps with Black Gates, and more recently with Nichicon, Rubycon, Panasonic and Elna caps. After trying each of those, I've centered on Nichicon.
But my favorite - if the capacitors aren't too large, 20uF and less - is to replace with polypropylene caps. Sometimes that's not a possibility though, if space is limited.
Hi Wayne,
I also like and use the Nichicon capacitors although I now use
polypropylene capacitors in decoupling applications.
20 ufd is getting a little physically large for me as well.
Back in the day, I used a couple of brands, the silver looking Infini caps
by TRT were the most accurate/natural, but the accuracy depended upon the ufd,
and nothing over 10 ufd was manufactured if memory serves me correctly.
Around 2 decades ago, the Infini became extinct (except by special order the
last time I checked), and I started using Mundorf in oil (after testing),
although I found some smaller value ufds not that ultra accurate, just like
other brands vary.
Wayne, I wonder how many truly understand the efforts we go to, to design
excellent components? Truly a labor of love.
Cheers
pos
Current Time: Sun Nov 15 04:08:41 CST 2026
