Home » Sponsored » Pi Speakers » 4pi: Cabinetmaker's build
4pi: Cabinetmaker's build [message #99291] Mon, 16 March 2026 21:35 Go to next message
dustboy is currently offline  dustboy
4pi parts are on order JBL 2226/DE250 (and backorder, in the case of the DE250-8's) and in the mean time I'm starting to work out the details.
I own a custom cabinet shop with 5x10 CNC router and edgebander, so building boxes is kind of my thing. But doing the engineering of building a speaker is way beyond my mental capacity so I'm glad to have found this design. I've built several kits before including Zaph Audio 5.2 and Adire Audio MTM.
I don't want to mess with success so I'll be sticking with the script for the most part.
-Would it be a bad idea to fillet the mouth of the port with a 3D printed flare? Or 3DP the entire port with flares at both ends? Presumably sharp outside corners produce turbulence and most ports I've seen have this feature. Would I want to change the length of the port if I do this?
-I have 2+ sheets of A1 MDF with a walnut veneer that are very nice and even better, free. I think most folks are using 18mm or thicker baltic birch these days, so I'll plan for more internal bracing. What is the intended enclosure volume? For whatever volume I displace internally I'll need to add to the total enclosure volume, yes? Which outer dimension is preferable to modify?
-I'm considering an inset baffle to allow a removable cloth grille panel to set flush.
-I will probably integrate a base, maybe some nice hardwood legs and try to make the speaker a bit less boxy looking.
Re: 4pi: Cabinetmaker's build [message #99295 is a reply to message #99291] Tue, 17 March 2026 15:29 Go to previous messageGo to next message
Sounds like it's going to be a cool build!
You can probably radius the edge of the ports without any ill-effects.  There's a formula for calculating the Helmholtz frequency of ports with radiused ends that could be used to see.  But then again, that port is huge - in a cabinet tuned and designed for full-range use rather than as a subwoofer.  So you won't hear any chuffing no matter how hard you push 'em.
Re: 4pi: Cabinetmaker's build [message #99322 is a reply to message #99291] Thu, 02 April 2026 22:52 Go to previous messageGo to next message
/forum/index.php?t=getfile&id=3558&private=0
I had some nice tweed grille cloth and these speakers being very, well, boxy, it seemed like a good reason to lean into the 'vintage monkey coffin' look. I mocked them up in sketchup, adding a 4" plinth that looked proportional.
I have a teenage boy who likes to use my listening room, and while he is pretty careful, his friends are likely to put a hole in my very expensive JBL woofers. So, removable grilles are mandatory.
I'd actually like to raise the speakers a bit higher to get them closer to ear level. The plinth might grow to 10-12", but it starts to look pretty chunky. In that case maybe a hardwood stand is more appropriate.
Re: 4pi: Cabinetmaker's build [message #99326 is a reply to message #99322] Fri, 03 April 2026 09:39 Go to previous message
I love that!  Looks great!
Previous Topic: 20uf or 10uf
Next Topic: Pi Speakers FAQ
Current Time: Sat Apr 04 01:42:18 CDT 2026
