| Re: Is it safe to position a Sub facing a room's side walls? [message #93727 is a reply to message #93726] |
Tue, 11 May 2021 15:43   |
The eighteens appear to go lower from the spec sheet, so I'd use those for subs if I could.
If we were considering flanking subs, I might lean towards a midbass driver 'cause it's used higher. Actually, probably both of your options are clean high enough to be used as flanking subs. But I am under the impression that won't work for you anyway.
I am a big proponent of the flanking sub configuration. I tend to setup flanking subs as my initial option, if space or funds constrain the installation to few subs. Then if I can go further, I use one or two more distributed subs in a Welti or Geddes configuration, whichever works best in the room.
But I didn't consider that approach 'cause I assumed from your descriptions that you cannot setup subs as flanking subs due to space constraints. Similarly, I also assumed that you couldn't use Welti or Geddes sub layouts because of limited placement options. Which left the approach of "just use more," placed wherever you can. That works too, as long as the subs aren't close to one another, which defeats the purpose of spreading them around.
| Re: Is it safe to position a Sub facing a room's side walls? [message #99324 is a reply to message #93733] |
Fri, 03 April 2026 00:11  |
Clint
Messages: 64 Registered: December 2025
Viscount |
mikehende wrote on Wed, 12 May 2021 07:04I will try to get a pair of the Subs should they ever become available in my area and will try placing one at the back wall and the other on the side wall in the middle of it. Will report back should I ever get those subs and will report back on the eaw placement issue, thanks.
Did you later get to do this? I would appreciate feedback if you did on the effects that it created.
Thanks.
