Home » Audio » Speaker » Latest waterproof speakers suited for a pool party (What are your best options?)
Re: Latest waterproof speakers suited for a pool party [message #99287 is a reply to message #99272] Sat, 14 March 2026 12:40 Go to previous message
George is currently offline  George
Kurt wrote on Mon, 09 March 2026 01:00
If you've got a bit of time, I would recommend you build your own simple waterproof speaker for the pool party that you are planning to host in the summer.
It will be fun building it and will surely cost less doing than getting a finished product from JBL, for example.
I hosted a similar pool party for just my family last year, and I spent didn't cross $60. The waterproof speaker driver was around $20, I spent $11 to get the  Bluetooth amp board, $10 for the rechargeable battery, and just 5 dollars for the sealed plastic enclosure
We had massive fun, and even water splashes on the speaker didn't affect the enjoyment. So, if you mind saving some bucks, building this yourself is the right way to go.
Building one myself has never crossed my mind, but this seems like what I should consider. Just maybe it is high time I am able to build a piece of musical tool that I use at home because I have always liked buying ready-made ones instead of building. Where's the best place you think I should buy the needed parts to do this?
Previous Topic: Recommended laptop speakers
Next Topic: Always Replacing Earbuds
Current Time: Fri Nov 13 17:44:07 CST 2026
