Home » Audio » Speaker » Latest waterproof speakers suited for a pool party (What are your best options?)
Latest waterproof speakers suited for a pool party [message #99269] Fri, 06 March 2026 23:31 Go to next message
George is currently offline  George
I've got plans to throw a fun pool party for my friends this coming summer, and I am looking for a good waterproof speaker that can be able to last longer and not get any issues with water splashes.
I mean the type of speaker that can give my friends and I the entertainment that can make our pool party exciting and fun. I've looked at Sony and JBL models since they are much popular, but I am torn between which one is better or even if there are cheaper brands out there that can be able to deliver what I need.
Has anyone used any of the speakers I mentioned at their own get-together? Which one worked, and what should I look out for when getting the one that I need?
Re: Latest waterproof speakers suited for a pool party [message #99272 is a reply to message #99269] Mon, 09 March 2026 01:00 Go to previous messageGo to next message
Kurt is currently offline  Kurt
If you've got a bit of time, I would recommend you build your own simple waterproof speaker for the pool party that you are planning to host in the summer.
It will be fun building it and will surely cost less doing than getting a finished product from JBL, for example.
I hosted a similar pool party for just my family last year, and I spent didn't cross $60. The waterproof speaker driver was around $20, I spent $11 to get the  Bluetooth amp board, $10 for the rechargeable battery, and just 5 dollars for the sealed plastic enclosure
We had massive fun, and even water splashes on the speaker didn't affect the enjoyment. So, if you mind saving some bucks, building this yourself is the right way to go.
Re: Latest waterproof speakers suited for a pool party [message #99287 is a reply to message #99272] Sat, 14 March 2026 12:40 Go to previous message
Kurt wrote on Mon, 09 March 2026 01:00
Building one myself has never crossed my mind, but this seems like what I should consider. Just maybe it is high time I am able to build a piece of musical tool that I use at home because I have always liked buying ready-made ones instead of building. Where's the best place you think I should buy the needed parts to do this?
Previous Topic: Recommended laptop speakers
Next Topic: Always Replacing Earbuds
Current Time: Thu Jul 02 06:37:51 CDT 2026
