Home » Sponsored » Pi Speakers » Request for Four Pi plan
Re: Request for Four Pi plan [message #99256 is a reply to message #99255] Tue, 03 March 2026 10:44 Go to previous messageGo to previous message
amigo is currently offline  amigo
Thank you very much for your warm hospitality.
In your Pi speaker, the compression driver and horn, corresponding to the tweeter, are mounted flush with the woofer in the enclosure. A large slotted port is located next to this location. Recently, many two-way speakers have the compression driver and horn assembly mounted independently outside the enclosure. Schematically, if the woofer and horn are properly spaced apart and the enclosure volume for the woofer is appropriate, what are the acoustic or structural differences compared to the Pi speakers?
Best, Chang-Hee
Previous Topic: Interested in corner horn plans
Next Topic: 4Pi plans
Current Time: Thu Oct 22 15:53:13 CDT 2026
