Home » Sponsored » Pi Speakers » Request for Four Pi plan
Request for Four Pi plan [message #99254] Tue, 03 March 2026 06:43 Go to next message
amigo is currently offline  amigo
Hi, Wayne,
Thank you for your kind arrangement. I wish to build a four Pi speaker here in Korea based on your kit. Could you please send me the plan for four Pi and three Pi Sub?
Best regards, Chang-Hee
Re: Request for Four Pi plan [message #99255 is a reply to message #99254] Tue, 03 March 2026 08:55 Go to previous messageGo to next message
You've got mail!
Re: Request for Four Pi plan [message #99256 is a reply to message #99255] Tue, 03 March 2026 10:44 Go to previous messageGo to next message
Thank you very much for your warm hospitality.
In your Pi speaker, the compression driver and horn, corresponding to the tweeter, are mounted flush with the woofer in the enclosure. A large slotted port is located next to this location. Recently, many two-way speakers have the compression driver and horn assembly mounted independently outside the enclosure. Schematically, if the woofer and horn are properly spaced apart and the enclosure volume for the woofer is appropriate, what are the acoustic or structural differences compared to the Pi speakers?
Best, Chang-Hee
Re: Request for Four Pi plan [message #99259 is a reply to message #99256] Tue, 03 March 2026 16:58 Go to previous messageGo to next message
That's a really attractive look.  We do that on the constant-directivity cornerhorns.
But I can't recommend that on our three Pi or four Pi model loudspeakers for a variety of reasons.  The main one is the possibility of shifting standing wave mode positions within the cabinet.  If you move the woofer or the port for aesthetics or to maintain the close distance between woofer and tweeter, then the standing waves inside the cabinet line-up differently.
That can be a problem, because in a cabinet this large, standing waves occur in the lower midrange.  That's a frequency that is tough to damp.  So we tackle that problem in two ways - by placing the sound sources carefully and by positioning damping material in the middle of the cabinet as well as along the walls.
I designed these cabinets with transmission line modeling tools in addition to more traditional Helmholtz modeling tools and I did the final alignments and verification with acoustic measurements.
So if you modify the layout, be sure to measure response and pay attention to the lower midrange.  You may want to build a test box so that it can be adjusted if it has some midrange ripple.
Re: Request for Four Pi plan [message #99261 is a reply to message #99259] Tue, 03 March 2026 18:08 Go to previous messageGo to next message
Great thankls for your explanation. The speaker is really subtly sensitive!
Re: Request for Four Pi plan [message #99264 is a reply to message #99259] Thu, 05 March 2026 04:46 Go to previous messageGo to next message
Hi, Wayne,
I could find the drivers, B&C DE250 and JBL2226HPL, here locally, and then I may just place the order only for the horn and the XO from your Parts and Options page. How can I ask Pi logo decal and Is the XO of fully assembled or as discrete components way?
Another question is the local distributor told me that JBL 2226H is not available but 2226HPL is OK and both are 'almost(?)' same drivers. But I am afraid whether thery are exactly same models. Would you mind giving me some hints on this?
One more question; When planning to attach a grille to the front of the four Pi speaker enclosures, it seems like the speaker box will have a slightly more bordered area than the front plate for shape reasons, and there will also be a frame for attaching the grille cloth, so I wonder if these will interfere with sound radiation from the front of the speakers. What precautions should I take?
Regards, Chang-Hee
Re: Request for Four Pi plan [message #99265 is a reply to message #99264] Thu, 05 March 2026 09:21 Go to previous messageGo to next message
We sell crossovers fully assembled and we also sell just the blank board.  When buying fully assembled, you'll notice there are options for component selections.  When buying the unpopulated raw printed circuit board, you obtain your own passive components and assemble it yourself.
The entry-level assembled crossover is very good.  It includes 18gu pure-copper air-core coils, polypropylene film capacitors and non-inductive resistors.  All brands are of high quality.
Upgrades available include larger 15gu coils, which is worthwhile, especially if you consider running a tube amp.  Various brands of capacitors can be selected, and Mills resistors can be selected as well.  Choosing any of those is largely buyer-specific, as they are all good brands making high quality components.
As for the drivers, make sure the compression driver is the 8Ω polyimide version, part number DE250-8.  The JBL 2226HPL is a fine substitute for the 2226H, as the only difference is cosmetic.  The 2226H is packaged and sold as a raw driver, whereas the 2226HPL is intended to be installed in a cabinet.
About grilles, they are often a "necessary evil" - often made more important because of pets, young children or other "hazards." Then again, sometimes they are an aesthetic decision.  Some speakers with grilles look fantastic.  But even the most acoustically transparent material isn't truly transparent.  Most don't color the sound too bad, but they do have a slight effect.
My suggestion is to make grilles removable so you can have "the best of both worlds."  The traditional way to do that was with mounting posts or Velcro.  Another way to do it that I really like is with magnets.  Small cylindrical neodymium magnets can be embedded in the baffle with mates embedded in the grille frame.  Simply drill a hole and press in the magnet, adding a dab of glue. Do this step ahead of veneering and when the grilles are removed, the main cabinet has no visible grille mounts.
Re: Request for Four Pi plan [message #99266 is a reply to message #99265] Thu, 05 March 2026 20:17 Go to previous messageGo to next message
Thank you for your pin-point explanation.  :)
Re: Request for Four Pi plan [message #99431 is a reply to message #99266] Sat, 23 May 2026 11:15 Go to previous messageGo to next message
Dear Wayne,
Now I am going to cut the birch plywood out into parts in meter scale. Just before doing that, one of my friend commented me that I may better to increase the depth a little bit of 10~15mm to compensate the internal volume reduction with introduction of the bracings and stiffners. And Of course there is some increasing effect by the glass wool loading inside. His comment is to ask you whether your plan dimension is already designed and given under all those consideration or slight adjustment should or may be made due to maintain the net internal volume. Would you mind giving me tips for this question?
Regards, LEE
Re: Request for Four Pi plan [message #99435 is a reply to message #99431] Sat, 23 May 2026 23:01 Go to previous messageGo to previous message
Use 19mm panels and maintain the dimensions in the plans.
A cross-brace should be installed between the woofer and tweeter, spanning front-to-back and side-to-side.  It stiffens the panels and also serves as a place to put a sheet of R13 damping material.
This sheet of damping material is very important.  It spans the entire width and depth of the cabinet, essentially splitting the interior of the cabinet into two sections.  It effectively traps midrange while allowing bass to pass right through.
Also place sheets of R13 to cover the interior top, side nearest the port and the rear.
Previous Topic: Interested in corner horn plans
Next Topic: 4Pi plans
Current Time: Mon Oct 19 15:07:37 CDT 2026
