Home » Audio » Source » Oiling Turntable Bearings
Re: Oiling Turntable Bearings [message #99233 is a reply to message #92642] Tue, 17 February 2026 23:34 Go to previous message
Cole is currently offline  Cole
I won't advise anyone to make use of a synthetic motor oil for cleaning the turntables because this oil contains detergents and some multi-grade properties that have the ability to attract moisture over a period and it can affect some delicate parts of the turntable.
I have been making use of liquid bearing 100% synthetic oil for a long time and it has done the work perfectly fine. Other alternatives are Project Lube it or sewing machine oil.
If you can find them in local shops around you, I would suggest checking out https://LPGear.com or TurntableLab.com for the oil that you need. https://LPGear.com was where I got the last one that I am still using to date.
Previous Topic: Where do you typically buy your music?
Next Topic: Ordered a Schiit Mimir DAC
Current Time: Thu Nov 12 22:50:55 CST 2026
