Home » Audio » Pro Sound » What are your top eco-friendly synthesisers for quality music production? (Which One are you currently using?)
Re: What are your top eco-friendly synthesisers for quality music production? [message #99190 is a reply to message #99180] Sat, 24 January 2026 07:33 Go to previous message
Clint is currently offline  Clint
Bercle wrote on Wed, 21 January 2026 23:22
I understand and appreciate you for thinking about the planet when it comes to using some of the devices.
The one that I've been making use of in sound production when I need to, no thanks to my work schedule, is the Teenage Engineering OP-Z. It was made with recycled plastic, has a good low-power draw, and is loaded with insane sequencing for amazing productions without crushing energy.
Not to say that the Roland AIRA or Korg Volca are not great alternatives, but I think OP-Z feels more versatile for layering tracks sustainably.
At the moment, I am rocking a combo of the OP-Z and a solar-supported Novation Circuit Rhythm...gives me those eco-friendly vibes.
So, tell me your genre? It could help me give you a better suggestion for your next upgrade.
My main genres right now are rock and country with a bit of Pop and I've been making use of the Roland AIRA Compact Series in producing most of the songs that I've done.
I know that there would be better options out there that will smoothly fit I to my genre of music with the mindset that they are also eco-friendly ones.
So, which one do you think that I should be aiming to get when I do the next upgrade of synthesisers which I use for making music?
On the side, I also think your OP-Z setup with the solar-powered circuit rhythm is awesome. Certainly gives that special vibe when making music.
Previous Topic: Wireless Quality Mike
Next Topic: What do you make of AI-assisted drum machines?
Current Time: Fri Oct 30 06:27:05 CDT 2026
