Home » Audio » Thermionic Emissions » Popular myths about tube amps (Which One surprises you the most?)
Popular myths about tube amps [message #99166] Sun, 11 January 2026 03:03 Go to next message
Kurt is currently offline  Kurt
I am someone who's invested a lot in keeping tube amps alive and it saddens me when I see some myths about thermionic emission around some communities.
Which ones have you seen recently?
Personally, I have one that I've seen and I would like to clear the air about them.
I've seen this myth that tube amps are inferior to solid-state. I believe this is absolute nonsense. I mean we've got recent tubes from brands such as Tung-Sol performing absolutely better than vintage Nos, for example. I've got the boutique 50W head doing well since 2019 when I got it. I've only done some routine bias checks and occasional tube replacement. I believe that reliability comes from great power supply design and not basically from pushing tubes beyond specs.
Which other ones do you have in mind that you think are wrong?
Re: Popular myths about tube amps [message #99169 is a reply to message #99166] Thu, 15 January 2026 08:28 Go to previous messageGo to next message
Kurt wrote on Sun, 11 January 2026 03:03
Hi Kurt,
I have also heard that myth about SS being better. Nothing could be further
from the truth. I have a couple of posts in this string, below, mentioning
just a few differences, and why SS will never be perfect to the source but
Tube amplifier can be extremely close.
One caveat to mention is that as one gets closer to perfect accuracy to the
source, one must be more careful to the "little" things.
As one example, I have been R&D analog since 1980, delving into audio
perception and component design, and use multiple 6N pure copper speaker wires
in parallel, for both minimal inductance at high frequencies, and total gauge
for optimal woofer damping (at least the best one can obtain).
Besides those two, one must consider a flat response over the entire audio
band since the speaker impedance changes (usually cone types) from minimal
to maximum. I have found that there is an optimal total gauge that will give
flattest frequency response, and most natural sound.
https://audioroundtable.com/forum/index.php?t=msg&th=21561&start=0&
Thanks for starting this string Kurt.
Cheers
pos
Re: Popular myths about tube amps [message #99364 is a reply to message #99169] Thu, 23 April 2026 10:01 Go to previous messageGo to next message
Hi, it is bogus.  (I am finally back see Tower) I have had a total of three listeners sell off their expensive SS amps (two were Mark Ls that ran over $11,000) for a pair of Oddwatts.  Tube amps are not better or worse that SS ones.  If well designed both will do the job well.  To be sure there some speaker that work better on one kind or the other.  I would not use many tube amps on current hungry speakers and would probably not use SS ones on many of the vintage high sensitivity speakers.  It is sort of like putting gas in a vehicle.  All types will generally work but some may work better in certain vehicles.
Re: Popular myths about tube amps [message #99398 is a reply to message #99364] Sat, 09 May 2026 00:05 Go to previous messageGo to next message
gofar99 wrote on Thu, 23 April 2026 10:01
You certainly said it the way it is. The thing is one needs to figure out what works with speakers that they intend using it on before arriving on a conclusion. Making the right decision, just like you said, makes it easier for all. DO you have specific speaker brands that you think can work with solid-state amps, for example?
Good to see you back, mate.
Wishing you the best of the weekend!
Re: Popular myths about tube amps [message #99403 is a reply to message #99398] Sun, 10 May 2026 23:44 Go to previous messageGo to next message
I for one will never use a SS amplifier (or preamplifier). It is all
tube for me except for the dac. There are just inherent problems with
SS that cannot be solved.
Tubes designs are a completely different story. I have described some of
the inherent problems with SS in another string called "Solid State vs
Vacuum Amps", in this Tube subforum.
I finished up my phono stage (except somewhat haywire look) and I do find
some LPs superior but costly, to high rez ss dacs).
Cheers
steve
Re: Popular myths about tube amps [message #99408 is a reply to message #99403] Mon, 11 May 2026 11:43 Go to previous messageGo to next message
Hi. Both an easy and hard question to answer. Any speakers that do not provide specs I would pass on.  Ones that do ... for tube use should be relatively high sensitivity.  I would want 90 db/w or better. If they give input impedance over the audio band width (unlikely) a more or less linear value would be desirable.  They will always have resonance peaks and probably drop off in the high end.  If it is excessive then many tube amps will probably have difficulty in that range. Another clue is physical size.  If the speaker is small (like less than a cubic foot) and they claim wide response they are likely inefficient.  See Theil's equations.  Essentially loudness, response and box size are interrelated.  That doesn't mean that you need something the size of a fridge although that would be really cool.  Specifics.  Any of Waynes speakers would work very well on tube amps of modest size.  Other than them, most 75 era klipsch, Alted Lansing and similar would be fine.  For newer stuff the only ones I am sure of are the Martin  Logan ESLs like I have. 20 watts rms is plenty to drive you out of the room.  Other ESLs are usually inefficient.  Also a what I call a useless spec often given for speakers is max power handling.  It really doesn't tell you anything useful.  I have seen extreme cases where a 3 inch paper cone speaker was listed as able to handle 1000 watts.  It would go incandescent immediately.
Re: Popular myths about tube amps [message #99612 is a reply to message #99408] Thu, 23 July 2026 16:40 Go to previous messageGo to next message
I'm not a technically adept enthusiast but have tube and SS amplification. Maybe one myth of tube audio is that it has this inherent warmth to it. Maybe some do. I use an OTL design tube amplification and I don't sense this cosy warmth as much as clarity and articulation with its sound. Fact is maybe my SS amp is more warm sounding. Hard to discern without side by side A/B listening. Which I don't have capability. But, I enjoy both.
Re: Popular myths about tube amps [message #99613 is a reply to message #99612] Thu, 23 July 2026 19:09 Go to previous messageGo to next message
Rusty wrote on Thu, 23 July 2026 16:40
I'm not a technically adept enthusiast but have tube and SS amplification. Maybe one myth of tube audio is that it has this inherent warmth to it. Maybe some do. I use an OTL design tube amplification and I don't sense this cosy warmth as much as clarity and articulation with its sound. Fact is maybe my SS amp is more warm sounding. It's hard to discern without side by side A/B listening. Which I don't have capability. But, I enjoy both.
I think at the end of the day, it is all about feeling at home with anyone that one decides to be using just like you mentioned that there are cases where some tubes amps ain't as warmth as anyone would assume that they are.
Re: Popular myths about tube amps [message #99616 is a reply to message #99613] Fri, 24 July 2026 11:16 Go to previous message
I'm an electrical engineer and I grew up in the 1960s and 1970s.  Those were years when tubes were in decline, and by the 1980s they were probably at their lowest acceptance point.
There are several disadvantages to tubes, and so I understand why they were being left behind in that era.  They are large, vulnerable and relatively power hungry.  They are not only vulnerable to physical damage but also to microphonics from vibration.  Combine that with our rapid movement in the digital realm and tubes were getting left in the dust.
My mindset tracked with those thoughts too.  I considered tubes an interesting piece of history, something like the horse and buggy. I enjoyed the nostalgia of a tube radio but didn't think they had a place in the future.  When I heard guitarists say things like "tubes sound better," I discounted their opinions because they also said things like "tube watts are louder than transistor watts," which I knew was nonsense.
A few facts started presenting themselves in the late 1980s and 1990s that slowly changed my opinion.
The first one was a realization that tubes are inherently resilient to lightning strikes and electrostatic discharge.  In the 1980s, one of the things I did was to design large lightning protection systems for computers and computerized controllers.  I used primary and secondary protection - Intentionally placing lightning rods to attract strikes to a known location as primary protection and incorporating surge-clamping diodes and other solid state protection devices as secondary protection on the power lines and the even more vulnerable computer interface lines.  The strikes would induce a current in the control and/or signal lines, and the SCD and/or MOV devices would clamp those.
I couldn't help but to ponder that a tube transmitter had a huge antenna just luring lighting towards itself, but it had a natural resilience to strikes.  The tubes might be vulnerable in some ways, but this is one way they were much less vulnerable to solid state.
The second thing I realized was that I had been mixing amplifier topology with single-element performance all my life.  What I mean by that is since transistors are so small, much more complex circuits can be built in the same space.  Naturally transistors are better for computers for that reason alone.  And even in the analog space, you can make a much more complex solid-state circuit in the same size chassis.  So you can employ numerous gain stages and feedback mechanisms in a solid-state amplifier, and those can be employed to reduce distortion.  So much of the performance gains of a solid state amplifier were actually from topology - You could design-in more gain stages and distortion-reducing negative feedback in a relatively small solid state amplifier.
But those extra gain stages and feedback loops have their own disadvantages too.  As the amplifier nears limits, the feedback loops become ineffective.  When the amplifier enters clipping because of the power supply limits, feedback can no longer work and distortion rapidly increases from nearly zero to nearly 100%.  An amplifier that isn't so dependent upon that mechanism may have a little more distortion through its normal operating range, but it doesn't rapidly rise as it nears clipping.  That "graceful clipping" is why those guitar players thought tube watts were "louder."  They weren't as nasty sounding when you pushed 'em hard.
And multiple stages introduce noise.  So having a very simple amplifier brings a benefit of the potential of super-low noise at quiescence.  Provided the power supply can be made pure, a simple class-A amplifier with few stages can be ultra-quiet.
Another little factoid - When distortion is even and particularly when it is mostly the lowest harmonics, the distortion is much less objectionable than higher orders.  So 4% purely second harmonic is much less ugly sounding than 1% THD, if the harmonics are mostly odd and high, like 5th, 7th and 9th.  Ironically, a solid-state amplifier that depends upon negative feedback for distortion reduction tends to have very low THD, but when it distorts, it's a mixture of all harmonics, low and high.
I was surprised to learn that when I compared two output devices - one a common tube and another a common transistor - the tube was actually much more linear than the transistor.  The transistor circuit actually depends upon negative feedback to actively clean up the signal it has produced.  A comparable tube is much more linear.
As an example, compare the 300B tube to a 2N3055 transistor.  Both are commonly used as output devices in audio amplifiers.
The 300B is a directly heated triode, celebrated precisely because its internal structure is inherently linear. Its transfer characteristic follows a smooth 3/2 power law. When plotted on a graph, its plate curves are remarkably straight, parallel, and evenly spaced. This means that as the music signal swings up and down, the tube scales the signal with minimal warping.
The 2N3055 transistor, by contrast, is an inherently non-linear device governed by an aggressive exponential law. At the bottom of the audio wave, it suffers from a sharp conduction turn-on curve. Even when biased deeply into pure Class A to keep the transistor permanently "on," its current gain still warps significantly depending on the temperature and the amount of current running through it.
When comparing both devices as open-loop single ended amplifiers without negative feedback, they share a common trait: they do not cancel out distortion and generate a dominant 2nd harmonic. However, the type and amount of distortion differ vastly.
The 300B creates predominantly low-order 2nd harmonic distortion, with a rapid, steep drop-off to the 3rd, and virtually undetectable higher harmonics (4th, 5th, 6th). At moderate volumes, the open-loop Total Harmonic Distortion (THD) sits around 1% to 3%.
The 2N3055 - or any other standard bipolar transistor for that matter - has an open-loop transfer curve that bends much more sharply than a tube. This sharp bend creates significantly higher overall distortion. More importantly, it creates a long trail of higher-order odd harmonics (5th, 7th, 9th).
So the truth is that tubes are actually vastly superior to transistors when it comes to linearity.
That one simple truth was kind of a shock to me.  I hadn't bothered to look at that in my youth, even a decade or so into my career.  I was mostly focused on computers and digital electronics, and in those realms solid-state is almost a requirement.  And solid-state output devices can handle a ton of current, so they're great for driving motors and other high-current loads.  Solid-state can be used to make excellent amplifiers too.  So I simply overlooked the truth of the matter which is that solid-state amps require topologies that employ negative feedback to mitigate the high levels of harmonic distortion they create.
Food for thought.
Previous Topic: Tube amps on PC.
Next Topic: What are the common issues that you've experienced with using different tube amps?
Current Time: Sun Oct 25 18:47:50 CDT 2026
