Home » Audio » Source » Ordered a Schiit Mimir DAC (Will test)
Ordered a Schiit Mimir DAC [message #99124] Wed, 03 December 2025 07:06 Go to next message
Well, I heard some nice things about the Schiit Mimir dac,
but wonder if it is hype, or descent, so I purchased one.
Should arrive fri.
Will report back with my findings in a couple of weeks.
cheers
pos
Re: Ordered a Schiit Mimir DAC [message #99126 is a reply to message #99124] Wed, 03 December 2025 09:35 Go to previous messageGo to next message
Those guys are kind of the "new kids on the block" and I'm eager to hear what you find.
Re: Ordered a Schiit Mimir DAC [message #99131 is a reply to message #99126] Tue, 09 December 2025 17:33 Go to previous messageGo to next message
Wayne Parham wrote on Wed, 03 December 2025 09:35
Hi Wayne and All,
Received the basic Mimir dac. No Forkbeard module, no preamplifier,
just the dac. Cost was $299 plus tax and shipping. Looks great, simple
to use.
Separate external power transformer supplied for linear power supply,
just plug in, or use the USB for power. Transformer use increases the
output voltage spec. I auditioned with both power sources.
Toggle power switch on back. No thumps on power on. Simple front
push button switch to activate individual inputs.
Basically no specs given, except usb supports up to 32 bits/384 khz.
Also came with 1 meter usb, A and C ends.
My computer is using VLC Media Player. I used the Mimir supplied usb
as I had none with C end as I had no other USB with C connector.
I used Tidal and YouTube. I have ~50 hours of play time. Sound seems to
be stabilized.
I don't take much stock in other's reviews because I know little about
the quality of the audio systems others use. Schiit also makes some
claims.
I have auditioned the Denafrips Pontus, basically all the Chords including
the Dave (12 grand), and probably another one or two from other audiophiles
and now I do not miss any of them.
The Mimir is simply incredible. The harmonic structure from deepest bass
through the highs is incredibly natural. Great dynamics, dimensions,
tonal balance, everything sounds amazing. With all polypropylene
decoupling capacitors in my audio system, years of listening testing,
we can perceive 1 part in 4,000,000. Using 20 log equation,
that is -132db down, so extremely transparent.
There is a sonic difference between YT and Tidal. I do not know how
Tidal sonically compares to Roon, Qobuz, Deezer etc.
In conclusion, the piano and other instruments sound so gorgeous
from deepest note to highest register. I still almost cannot believe it.
I guess one can conclude I highly recommend it.
Cheers
pos
PS. I do Not have any affiliation with Schiit Audio.
Re: Ordered a Schiit Mimir DAC [message #99133 is a reply to message #99131] Wed, 10 December 2025 16:59 Go to previous messageGo to next message
That's amazing, especially for three hundred bucks.  My kinda DAC!
Re: Ordered a Schiit Mimir DAC [message #99134 is a reply to message #99133] Wed, 10 December 2025 19:06 Go to previous messageGo to next message
Wayne Parham wrote on Wed, 10 December 2025 16:59
I received my B to C adapter, so now my 2 meter USB, and went from
2 meter ic to 1 meter,both ics are my build/design.
If I can find fault, it might be just a little full, but yet
the bass sounds quite taught. The coherency, live sound is quite
impressive.
There is a small restocking fee plus shipping, but I think
there will be very few returns.
I don't see how anyone can lose.
Cheers
steve
Re: Ordered a Schiit Mimir DAC [message #99163 is a reply to message #99134] Wed, 07 January 2026 19:49 Go to previous messageGo to next message
Probably need to add, that with my computer win 10, Schiit supplied
outboard power transformer makes Mimir sound better, more natural than
my win 10 usb power supply. USB power source sounds thinner.
I would try both to hear what sounds best on your system.
cheers
pos
Re: Ordered a Schiit Mimir DAC [message #99164 is a reply to message #99163] Thu, 08 January 2026 08:47 Go to previous messageGo to next message
That makes sense to me.  It has been strange to me to see how many modern power connectors are small, with little surface area for the contact and small conductor wires.  For 100mA, I wouldn't care but many try to get several amps of current though these tiny connectors.
Re: Ordered a Schiit Mimir DAC [message #99214 is a reply to message #99164] Fri, 06 February 2026 12:02 Go to previous messageGo to next message
Wayne Parham wrote on Thu, 08 January 2026 08:47
I agree Wayne. Seems everything has to be smaller, even if it is inferior.
I just added, via pigtails, Vampire gold plated copper
jacks to my Schiit Mimir analog outputs, using Jenalabs wire. What a
sonic improvement of the Vampire vs the original brass jacks.
Sounds so much more natural.
cheers
pos
Re: Ordered a Schiit Mimir DAC [message #99270 is a reply to message #99214] Sat, 07 March 2026 19:44 Go to previous messageGo to next message
Adding the pigtails copper rca output jacks (Jenalabs 6N
all copper wire) made a nice improvement to the Mimir,
more natural sound, great spatial qualities.
Just received some parts fri and now testing a possible upgrade.
Will take some time for break in, time will tell. Will keep
informed.
cheers
pos
Re: Ordered a Schiit Mimir DAC [message #99271 is a reply to message #99270] Sun, 08 March 2026 09:29 Go to previous messageGo to previous message
Sounds like that DAC is really working out for you!
Previous Topic: Oiling Turntable Bearings
Next Topic: Digital looks so simple, sometimes I miss the vinyl ritual
Current Time: Thu Nov 12 22:10:47 CST 2026
