Home » Audio » Silicon Valley » Amp under desk
Amp under desk [message #87648] Mon, 02 April 2018 20:21 Go to next message
Ouroboros is currently offline  Ouroboros
I've seen some cool looking workstations where people have mounted their amps underneath their desks. Would there be any downsides to doing this? Other than saving space, are there any benefits? I've also read that there should be enough room for airflow between the top of the amp and the desk. How much space do you think is necessary?
Re: Amp under desk [message #87655 is a reply to message #87648] Mon, 02 April 2018 21:29 Go to previous messageGo to next message
Hi That would depend on the amp. If it is a class D one then probably nearly no clearance is needed as they put out little heat. If it is a large class A tube amp...then at least 6 inches all around and IMO I would not put one there in the first place. I have put PCs under the desk on occasion...but with plenty of clearance ...especially around the back where many have fans.
Re: Amp under desk [message #99071 is a reply to message #87655] Mon, 03 November 2025 11:50 Go to previous messageGo to next message
Helen is currently offline  Helen
I haven’t tried mounting an amp under a desk, but I have seen pictures and it does look really tidy. I don't think there are any downsides to keeping it underneath the desks. The only thing to look out for is to watch out for heat, since amps can get warm.
Maybe leaving a few inches of space on top would help with airflow. I’m not sure if there are many extra benefits besides saving space.
Re: Amp under desk [message #99425 is a reply to message #87655] Fri, 22 May 2026 12:11 Go to previous message
Hank is currently offline  Hank
gofar99 wrote on Mon, 02 April 2018 21:29
You are right in terms of how the amp is built. I can't place a huge solid-state amp under the desk because of risk of overheating. It is not the ideal way to set it if one wants their gears to last for a long time.
Previous Topic: Do you think getting a customised solid-state amp is a waste of money?
Next Topic: What's your say about Quilter amps?
Current Time: Sat Nov 21 02:37:23 CST 2026
