Home » Audio » General » Amp choices for multi-amp config
Re: Amp choices for multi-amp config [message #989 is a reply to message #988] Mon, 18 October 2004 16:23 Go to previous messageGo to previous message
grmngr is currently offline  grmngr
most people use plate amps for subs even if they use tubes up top. be careful of amps or parts
that only go to 12k. compression drivers are one thing but all chips, tubes and transistors go
much higher than that. transformers and capacitors should too unless they are very cheap.
mediocre output transformers are usually the culprit.
Previous Topic: AR Turntable website unveiled
Next Topic: !!! Woodstock 25,000th Post Contest !!!
Current Time: Fri Nov 27 04:52:02 CST 2026
