Home » Audio » Thermionic Emissions » TAD KT88 (Sound quality? Other info?)
Re: TAD KT88, Mullard [message #98811 is a reply to message #98794] Tue, 12 August 2025 14:14 Go to previous messageGo to next message
I got a pair of Mullard KT88 tubes today.  Soon, I'll swap 'em out on my Audio Note Kit 2 and give 'em a few weeks listening time.  Then I'll report back.
I also noticed on another thread that pos was asking about quiescent current in the Audio Note amp.  I'll try to remember to open up the bottom, power it up and measure the voltage across the cathode resistors to know the current.
Re: TAD KT88, Mullard [message #98812 is a reply to message #98811] Wed, 13 August 2025 22:42 Go to previous messageGo to next message
Wayne Parham wrote on Tue, 12 August 2025 14:14
Looking forward to your research and findings Wayne.
cheers
pos
Re: Mullard KT88 [message #98826 is a reply to message #98812] Mon, 08 September 2025 12:15 Go to previous messageGo to next message
OK, so I've had my new Mullard KT88 tubes in my amplifier for a little less than a month now and have listened for probably a couple dozen hours or so, mostly in two hours stretches or thereabouts.  So it's time to report back.
This is just a listening evaluation without measurements, and that's something I normally don't do.  That said, take this post for what it is.  Total seat of the pants observation.
So far, I think I like these tubes.  They are somewhere between the Tung-Sol 6550 and the Electro-Harmonix 6550 in the range of smoothness.  Neither of those tubes lack smoothness, but the EH sounds a little more detailed and the TS sounds a little more laid-back.  The Mullard KT88 is sort of in-between.
To be honest, I am interested also in the longevity of these Mullards in my Audio Note Kit 2.  I think I may have mentioned this here or in another thread, but just in case I hadn't, I find that KT88 tubes don't last as long as 6550 tubes.  They don't fail right out of the box, but they do seem to have a shorter lifespan.  We'll see on these.
They do sound nice though.  Time will tell if they get to be "regular stock" tubes for me like the Tung-Sols and the Electro-Harmonix.
Re: Mullard KT88 [message #98829 is a reply to message #98826] Thu, 11 September 2025 23:02 Go to previous messageGo to next message
Wayne Parham wrote on Mon, 08 September 2025 12:15
Thanks for your report Wayne. I think we both agree on the sound vs the
TS 6550. As mentioned previously, I am running the tubes idle at
~440 P-K volts with cathode bias.
As mentioned in another post somewhere, I had a TS short with less than a
thousand hours, and side getters quite used on all 4 of the tubes.
I have not tried with higher P-K voltage and/or with fixed bias with the M
tubes.
So far, I am very pleased with the new Mullard KT88s. Will keep in touch
if any problems.
Cheers
pos
Re: Mullard KT88 [message #98830 is a reply to message #98829] Mon, 15 September 2025 08:50 Go to previous message
I'll report back if I run into any problems with these tubes as well.
Previous Topic: New Production Tung Sol 6550, Penta KT88s
Next Topic: Solid State vs. Vacuum Amps
Current Time: Sun Oct 18 16:00:33 CDT 2026
