| Re: Mullard KT88 [message #98826 is a reply to message #98812] |
Mon, 08 September 2025 12:15   |
Messages: 18984 Registered: January 2001
OK, so I've had my new Mullard KT88 tubes in my amplifier for a little less than a month now and have listened for probably a couple dozen hours or so, mostly in two hours stretches or thereabouts. So it's time to report back.
This is just a listening evaluation without measurements, and that's something I normally don't do. That said, take this post for what it is. Total seat of the pants observation.
So far, I think I like these tubes. They are somewhere between the Tung-Sol 6550 and the Electro-Harmonix 6550 in the range of smoothness. Neither of those tubes lack smoothness, but the EH sounds a little more detailed and the TS sounds a little more laid-back. The Mullard KT88 is sort of in-between.
To be honest, I am interested also in the longevity of these Mullards in my Audio Note Kit 2. I think I may have mentioned this here or in another thread, but just in case I hadn't, I find that KT88 tubes don't last as long as 6550 tubes. They don't fail right out of the box, but they do seem to have a shorter lifespan. We'll see on these.
They do sound nice though. Time will tell if they get to be "regular stock" tubes for me like the Tung-Sols and the Electro-Harmonix.
| Re: Mullard KT88 [message #98829 is a reply to message #98826] |
Thu, 11 September 2025 23:02   |
positron
Messages: 148 Registered: May 2020
Master |
Wayne Parham wrote on Mon, 08 September 2025 12:15
Thanks for your report Wayne. I think we both agree on the sound vs the
TS 6550. As mentioned previously, I am running the tubes idle at
~440 P-K volts with cathode bias.
As mentioned in another post somewhere, I had a TS short with less than a
thousand hours, and side getters quite used on all 4 of the tubes.
I have not tried with higher P-K voltage and/or with fixed bias with the M
tubes.
So far, I am very pleased with the new Mullard KT88s. Will keep in touch
if any problems.
Cheers
pos
