Home » Sponsored » Pi Speakers » My 4 Pi Build
Re: My 4 Pi Build [message #98756 is a reply to message #98753] Sat, 05 July 2025 09:06 Go to previous messageGo to next message
No, I mount them on a gasket.
Re: My 4 Pi Build [message #98757 is a reply to message #96988] Sun, 06 July 2025 10:46 Go to previous messageGo to next message
Gotcha.  For now I mounted them with some #12 screws using a couple of washers to space them off the surface.
I was eager to make the speakers ready for listening using materials that I had on hand.  It happened that I had exactly enough leftover R-13 to line the three sides of the enclosures, and I used R11 on the brace between the woofer and horn.  I didn't have any white glue so I tacked the sheets in with staples.
/forum/index.php?t=getfile&id=3517&private=0
The crossovers went in next.  The holes were marked and pre-drilled after the cabinet was put together, which was only possible using a 90 deg drill because of limited clearance with the brace at the woofer midpoint.  In hindsight it would have been better to drill the panel before assembly.   Getting the nylon spacers to line up was a little fiddly...
/forum/index.php?t=getfile&id=3518&private=0
Drivers installed...I've omitted the gaskets for now.  I'm working off the assumption that the DNA-360 are the same polarity as the DE-250, but I'll know for sure once I measure @ crossover point.
/forum/index.php?t=getfile&id=3519&private=0
The 2226 rests a little more proud above the motorboard than I would like, but it's too late to change at this point.  The recess depth I went with is 1/2" however another 1/8 would've been about right.  Not that 1/8 in. would make a difference, but I'm curious if the disparity in time alignment has a noticeable impact on imaging.
/forum/index.php?t=getfile&id=3520&private=0
The assembled speakers are heavy and I had some help moving them from the shop into the house where they displaced my Forte IIs.  I only had about five minutes to listen to them as we are hosting my brother's family with three small kids for a couple of weeks and they had already planned to watch a movie in the same room.
I'll report back once I get another chance.
/forum/index.php?t=getfile&id=3521&private=0
Re: My 4 Pi Build [message #98758 is a reply to message #98757] Sun, 06 July 2025 17:39 Go to previous message
Oooh, very nice!
Looks great!
On the woofer being 1/8" shy of flush - That's a total "don't worry about it" thing.
These speakers are purpose-designed to have a forward lobe that's pretty tall.  The drivers are in-phase between the vertical nulls, where they become out-of-phase.  And those vertical nulls occur above and below the speaker +/-20°.  So fore/aft offsets of either woofer or tweeter simply shift the forward axis vertically.  And when it's a small offset like that, we're talking about a very small angular difference.
You could calculate the shift made by moving the woofer forward 1/8" if you wanted, but I'm going to give a seat-of-the-pants guess of 0.25° to 0.5°, something like that.  Tiny.
With a 40° vertical pattern, I don't mind vertical shifts of even a few degrees.  I recommend stands with 3° to 5° tilt-back, to help cradle the speaker against the backrest, which is actually more of a lip than a rest.  But my point is those stands shift the verticals to from about +22° to -18° to about +25° to -15°, all of which is great too.
While you're measuring stuff, find those vertical nulls.  Put the microphone straight in front of the speakers, and then move the mic above and below the speakers 'til you find a sharp notch in the crossover region.  Those are the vertical nulls.
To me, the biggest thing that makes imaging great is the horizontal toe-in.  Cross the forward axes of the speakers just ahead of the listening area.  When you do that, the "sweet spot" becomes "anywhere between the two speakers."  Imaging is great throughout a fairly wide area.
Previous Topic: Ten happy years with the 3pi... Time for the Pi 3 subs!
Next Topic: 1 PI vent
Current Time: Mon Sep 01 06:51:45 CDT 2025
