Home » Audio » Source » Different Audio Players (Their Sonic Quality)
Different Audio Players [message #98557] Tue, 13 May 2025 11:23 Go to next message
I found these 4 digital audio players and wondered if anyone has experience
with their audio quality? Audio quality is most important to me.
AIMP
Spotify
VLC
Foobar 2000
Thanks
pos
Re: Different Audio Players [message #98558 is a reply to message #98557] Tue, 13 May 2025 18:19 Go to previous messageGo to next message
You listed VLC - Are you referring to the open-source VideoLAN Client media player, commonly called VLC?
Re: Different Audio Players [message #98560 is a reply to message #98558] Tue, 13 May 2025 22:42 Go to previous messageGo to next message
Wayne Parham wrote on Tue, 13 May 2025 18:19
Opened up, Help, and it says.
"VLC Media Player
3.0.21 Vetinari
VLC Media Player is free and open source Media Player, Encorder,
and Streamer made by the volumteers of the VideoLAN community."
I really don't know much, but it plays video and/or audio, depending
upon my windows 10 setting.
I have not looked any further.
A website reviewing half a dozen players stated AIMP excels at audio
quality, but at the end of the article mentioned Foobar 2000 as being
great with audiophiles. Confusing.
pos
Re: Different Audio Players [message #98563 is a reply to message #98560] Wed, 14 May 2025 14:34 Go to previous messageGo to next message
I've used VLC for a long time and I really like it.  That said, it is obviously dependent upon codecs and hardware, and there are setting that can and will affect quality.
Re: Different Audio Players [message #98580 is a reply to message #98563] Mon, 19 May 2025 20:57 Go to previous messageGo to next message
Hi, I prefer VLC as well.
Re: Different Audio Players [message #98582 is a reply to message #98580] Mon, 19 May 2025 21:26 Go to previous messageGo to next message
I will test my audio system tomorrow with VLC to see how the settings sound.
I have everything disabled and VLC set to see my dac in tools section.
Thanks gents and add whatever settings you think I should try.
Any others who have some input, most welcome.
pos
Re: Different Audio Players [message #98594 is a reply to message #98582] Tue, 20 May 2025 13:32 Go to previous messageGo to next message
I went to some videos and they were helpful.
Tools, preferences, clicked all. Clicked audio, stereo but no dolby.
Went from 4 to 10,
sync function to best quality
Under filters, lots of choices. All are left unchecked.
Do I need to do anything else?
cheers
pos
Re: Different Audio Players [message #98599 is a reply to message #98594] Wed, 21 May 2025 11:06 Go to previous messageGo to next message
positron wrote on Tue, 20 May 2025 13:32
Went from 4 to 10,
cheers
pos
I can confidently say that with the changes listed above that VLC
is clearly the best, most natural audio program I have heard so far.
It makes Media Player etc sound very average.
The music just sounds more live. Thanks Wayne and Gofar for your
suggestions.
I found a couple of more settings to change. Any other suggestions?
pos
Re: Different Audio Players [message #98679 is a reply to message #98557] Sat, 07 June 2025 16:42 Go to previous messageGo to next message
Chloe is currently offline  Chloe
From what I've heard, Foobar2000 is the best audio player. I don't have experience with it, but it seems to be the most accurate and it has a lot of options.
Re: Different Audio Players [message #98690 is a reply to message #98679] Wed, 11 June 2025 12:29 Go to previous message
Chloe wrote on Sat, 07 June 2025 16:42
Thanks Chloe. May I ask what you are using now, or in the past?
I also just tried Foobar2000 and will compare it with VLC,
hopefully this evening. (Results may vary being system dependent.)
One thing I read is that Foobar bypasses the win 10 audio mixer/engine,
which from my understanding VLC does not. Can anyone verify either way?
Once again thanks Chloe. Looking forward to the experiment.
pos
Previous Topic: Ethernet and USB Cable Comparisons
Next Topic: Repairing old CDs and DVDs
Current Time: Sat Nov 14 03:19:04 CST 2026
