Home » Audio » Thermionic Emissions » DH rectifier connection
DH rectifier connection [message #9846] Tue, 24 October 2006 23:14 Go to next message
Need some clarification please.
When using a DH rectifier like a 5Y3GT, the power trannies secondary leads go to pins 4 and 6 with the PT's center tap grounded? Then the 5V filament leads go to pins 2 and 8, with the B+ connection to the first filter cap coming off of pin 8 or the B+ connection coming from the center tap of the 5V winding if it has a center tap (with the two main heater leads still at pin 2 and 8)?
Re: DH rectifier connection [message #9847 is a reply to message #9846] Thu, 26 October 2006 21:39 Go to previous message
Yes, you are correct. If your heater winding has a CT, you can tap your B+ from it.
I use pin 8, then if I want to switch to an indirectly heated rectifier you have a direct connection to the cathode…John
Previous Topic: Trannie DCR's
Next Topic: Re: Counterpoint SA-7 Schematic Needed
Current Time: Fri Nov 06 10:55:55 CST 2026
