Home » Sponsored » Pi Speakers » Two Pi Bassreflex plan
Two Pi Bassreflex plan [message #98442] Tue, 15 April 2025 03:43 Go to next message
ecc82 is currently offline  ecc82
Hello Wayne,
I lost my plans for the 2Pi.
Is it possible to send the plan again?
Thank you very much and best wishes from Germany.
Frank
Re: Two Pi Bassreflex plan [message #98443 is a reply to message #98442] Tue, 15 April 2025 11:22 Go to previous messageGo to next message
You've got mail!
Re: Two Pi Bassreflex plan [message #98444 is a reply to message #98443] Tue, 15 April 2025 12:34 Go to previous messageGo to next message
Thank you very much!
Re: Two Pi Bassreflex plan [message #98447 is a reply to message #98444] Wed, 16 April 2025 05:11 Go to previous messageGo to next message
Wayne,
I have the "new" DX25 Tweeter, which is 2db "hotter" than the old one.  I would love to tame it a little bit.
How can I attenuate it?
Is it possible with a series resistor?
Best regards,
Frank
Re: Two Pi Bassreflex plan [message #98448 is a reply to message #98447] Wed, 16 April 2025 11:51 Go to previous messageGo to next message
We use the DX25TG59-04, which delivers 93dB @ 2.83v, measured at one meter.
Which tweeter do you have?
Re: Two Pi Bassreflex plan [message #98449 is a reply to message #98442] Wed, 16 April 2025 12:30 Go to previous messageGo to next message
I use exactly this model - but didn't you use the DX25TG09-04 before?
I have read,that the DX25TG09 was 2db less efficient.
My source:
https://sites.google.com/site/undefinition/updates/amigadx25tweeterupdate
Re: Two Pi Bassreflex plan [message #98450 is a reply to message #98449] Wed, 16 April 2025 14:25 Go to previous messageGo to next message
Yes, we used the DX25TG09-04 before the current DX25TG59-04.  And before that, we used the DX25TG05-04.
To be honest, the whole reason we use a 4Ω tweeter is to get the voltage sensitivity up to match the midwoofer.  Not many dome tweeters are sensitive enough to "keep up," so we "cheat" by using a 4Ω part.
At 2.83v, the midwoofer gets one watt but the tweeter gets two.  So even though the tweeter is rated 90dB/W/M, it's getting 2 watts, so that increases SPL by 3dB.  Said another way, it's 93dB/2.83v/M.  That's still a couple dB lower than the midwoofer, but it's a pretty good match and it sounds good.
Re: Two Pi Bassreflex plan [message #98451 is a reply to message #98450] Wed, 16 April 2025 15:31 Go to previous message
Wayne,
thanks for the clarification.
Previous Topic: JBL 2226
Next Topic: 4 Pi Speaker
Current Time: Mon Nov 09 00:19:31 CST 2026
