Rusty Messages: 1416 Registered: May 2018 Location: Kansas City Missouri
When I helped a friend build a pair of 2Pi tower speakers using MDF. We found that veneer to cover front, top & sides would be more expensive than thin solid wood. We glued up for width and used wood glue to apply on to the MDF. I'd done that with my own speakers and it's stood up to the test of time. Also using water based polyurethane used for flooring helps with humidity. And where I live in the summer is very humid. Just an option among many others for you to figure on.
Thanks for that, I'll have a look and see what's available. At the moment I'm planning on veneer for the sides, top and bottom and a paint finish front and back. Partly for cost reasons as 20" wide strips of nice veneer are very expensive and partly to be able to help the speakers blend with the room a bit better. They're not as tall as my current speakers but are over 6" wider.
Next job is to source crossover components and binding posts, I've made a cutting plan for the cabinets to come from 2 sheets of 18mm MDF with enough left over to make two braces per cabinet and the extra pieces for the baffle to allow the drivers to be flush mounted.
The sides and top will be veneered in Khaya wood (from the mahogany family I think but not quite as red as many of that family are). Front and rear will be a complementary paint finish that I haven't quite decided upon yet.
Should have time to get the MDF collected next week and start cutting and constructing the following week.
Hope you'll provide a pictorial of your speaker build. And, you're going to love hearing what your sweat equity brought forth.
There's some pics here under the heading of 2Pi Towers down the page a little showing what we used on my friends pair of speaker. We used Ash wood. I looked up Khaya wood and that's beautiful looking. It would be stunning. Bet it's costly. But hey, you're going to live with it for a long time. And you only live once. So let the good times roll.
Wayne Parham Messages: 18961 Registered: January 2001
Soulman wrote on Mon, 20 January 2025 03:03
Enough Khaya veneer to do the sides, tops and bottoms was £50 so not too bad. MDF is £30 a sheet and plywood is £140 a sheet so I'm still saving enough to pay for the crossover components, binding posts and anything else I might need
