Home » Sponsored » Pi Speakers » 3 Pi build
3 Pi build [message #98227] Sat, 04 January 2025 13:56 Go to next message
Soulman is currently offline  Soulman
I've decided to build a set of 3 Pi speakers using the B&C DE250 and 12PLB100 drivers.
I have a few questions.....
1. Birch ply or MDF?
2. Baffle mounted on the front or inset to the frame (sides, top and bottom)?
There's going to be more as I get into the build but I want to plan the cabinet first.
Re: 3 Pi build [message #98228 is a reply to message #98227] Sat, 04 January 2025 15:12 Go to previous messageGo to next message
If you will put the speakers in place in your home and rarely move them, I would prefer MDF.
On the other hand, if you plan to move the speakers regularly or expose them to a high-humidity environment, then go with Baltic Birch.
MDF is a little better acoustically, but Baltic Birch is a little better architecturally. Both are good, but I prefer MDF where speakers will be set in place permanently. It is much heavier though, and it is easy to dent. And it "turns mushy" when it gets wet.
As for the options of surface mounting versus flush, I prefer flush for aesthetics but there really is no acoustic benefit. Both are fine acoustically.
Re: 3 Pi build [message #98231 is a reply to message #98227] Sun, 05 January 2025 08:33 Go to previous messageGo to next message
MDF and ply are either 15mm or 18mm, I can build with 18mm ply and adjust the measurements externally to be a bit bigger without causing an issue? Just need to keep internal volume the same?
Re: 3 Pi build [message #98232 is a reply to message #98231] Sun, 05 January 2025 09:53 Go to previous messageGo to next message
I often use 18mm Baltic Birch. When doing so, the main thing to consider is port length. The effects from the minor change of internal displacement are small, so I am not as concerned about that as the port length. The port needs to remain 63.5mm. It can be off by a millimeter or so either way, but no more.
When making the port with 18mm stock, cut three 100mm squares. Plane one of those down to 9mm thickness. Glue all three - two 18mm thick and one 9mm thick - squares onto your baffle, centered where the port hole will be cut. Glue and clamp them in place. And then use a 2-1/2" hole cutter to drill the port hole through the baffle and port blocks. Something like this:
That will create a port that's 63mm diameter and 63mm long.
Re: 3 Pi build [message #98235 is a reply to message #98232] Mon, 06 January 2025 08:34 Go to previous messageGo to next message
Thanks Wayne, I'll have a think about which material to make them from. I'll be careful with the port dimensions as it seems crucial to the build. What frequency does that tune them to or is it room dependent?
It looks like it'll all come out of one 8'x 4' and one 4'x 4' sheet of whichever material I choose to use. Can I make braces from MDF or does the hardwood 1" x 2" stock work a lot better?
Re: 3 Pi build [message #98236 is a reply to message #98235] Mon, 06 January 2025 09:07 Go to previous messageGo to next message
The Helmholtz frequency is 30Hz. What is also important is the positions of the woofer and the port in the cabinet, as they determine how the standing waves line up inside the cabinet. It's not a transmission line - so it not tuned by quarter-wave resonance - but in a cabinet this size, they do exist in the upper midbass and lower midrange. That's why driver and port location are important - we don't want an antinode in either position. It's also why the damping material inside is important, especially the sheet that spans the cross-section.
The brace can be made using panel scrap. Just fit it snug so that the panels are slightly preloaded. And like I said, make sure a sheet of insulation lays on the brace. It should span the cross-section of the interior from side to side and front to back.
Re: 3 Pi build [message #98237 is a reply to message #98236] Tue, 07 January 2025 05:45 Go to previous messageGo to next message
Could I make them from 15mm ply and double up the front baffle to 30mm? I'd adjust the internal pieces for the port to make it work and keep the internal volume as close as possible.
I can flush mount the horn and driver then another front would be stiffer (if that would make any difference).
I was thinking of making the internal braces from 2 pieces of ply (an interference fit) and cutting lots of large holes in them. One above the woofer and one below (or cut to fit around it). Is this too much or will it alter the panel resonance frequency too much?
I'm assuming you prefer MDF for it's lack of large voids, consistency of density and ability to absorb sound waves more than ply?
Re: 3 Pi build [message #98240 is a reply to message #98237] Tue, 07 January 2025 11:20 Go to previous messageGo to next message
You could use 15mm panels, but that doesn't help you reach the goal of a 63.5mm port. We don't want a 60mm port - that's just a little too short. But you could perhaps do that and add a thin sheet of something to bring it up. Whatever you need to do to get it up to 63mm.
And to be honest, I don't think you'll want to double the thickness of the whole front baffle. It won't offer much but will make the cabinet very heavy. What I like doing is to double up just the area around the drivers and the waveguide.
Cut a circle that's a little larger than the woofer and a rectangle that's a little larger than the waveguide. Something like 5cm larger overall, for example. Glue and clamp them to the baffle side facing inward and cut the woofer and waveguide holes through them. It doubles the thickness of the panel in the area around the drivers so you can route a groove for flush mounting without making the routed "lip" on the baffle too thin.
As for my preference to MDF, it's not so much avoidance of voids as it is that MDF is a "different animal" entirely. In my opinion, it is the best single sheet panel, e.g. non-CSD, to build loudspeakers with. It's made using a variety of wood types, all shredded and combined with resins to form a pulp. That is heated and pressed to form a dense panel.
When working with plywood - as you've said - I do worry about voids. But the way I avoid the voids is to use Baltic Birch. The plies in Baltic Birch are so thin that any voids are completely filled with the adhesive that holds them together. So this greatly reduces any chance of having a panel with a void.
But even void-free Baltic Birch isn't as dense as MDF. I don't really have a problem with panel resonance with either one, because panel resonance is outside the woofer chamber's passband. But I do prefer MDF if the cabinet won't be moved a lot or exposed to moisture.
To be honest, the biggest potential problems are caused by unwanted cavity resonances, which is what I think attracts open baffle enthusiasts - they avoid cavity resonance. But open baffles have their own sets of problems, and so I prefer to deal with the cavity resonances a different way. That's done by careful positioning of the midwoofer and the port and by using damping material inside that's placed in such a way that it is most effective at damping cavity resonance.
Which brings me to your question about bracing, since it serves double-duty as a positioning device for a very important piece of damping material - the one that spans the cross-section. The brace must be placed between the woofer and the waveguide, and a sheet of insulation must rest upon it, spanning the entire width of the cabinet front-to-back and side-to-side. Having the insulation placed some distance from top and bottom cabinet panels helps improve its damping ability in the lower midrange. This is the one I know must be there, because it has been designed by modeling and confirmed by testing.
You can also place a similar brace just below the woofer, between it and the port. If you do so, it wouldn't hurt to place another sheet of insulation there, again, spanning the cross-section. This will separate the woofer and the port. Bass will pass right through though, so it will not adversely affect bass performance at all. It will only have an effect at midrange frequencies and higher.
Re: 3 Pi build [message #98243 is a reply to message #98240] Thu, 09 January 2025 13:14 Go to previous messageGo to next message
Wayne thank you for the in depth reply and added information that you're giving me.
I think I've decided on 18mm birch ply with the extra pieces (mounting the drivers flush, bracing the cabinet and making the port) made from 15mm birch ply.
I'll probably round over or chamfer the edges and then finish with teak oil or wax polish.
I've ordered the B&C 12PLB100 drivers so need the crossover components and binding posts.
What do you suggest for damping material?
Re: 3 Pi build [message #98244 is a reply to message #98243] Thu, 09 January 2025 15:04 Go to previous messageGo to previous message
I always use R11 or R13 fiberglass insulation.
Previous Topic: Waveguide mistake
Next Topic: Happy Pi Day!
Current Time: Thu Nov 05 13:57:33 CST 2026
