Home » Audio » Pro Sound » Software to visualize sound waves
Software to visualize sound waves [message #98171] Sun, 29 December 2024 19:49 Go to next message
My anniversary is coming up and I'd like to create some artwork for my wife that shows the sound waves of a song. The sound waves will depict part of the chorus from the first time we danced together at our wedding reception. Which piece of software do you recommend for visualizing this project? I'm either going to etch the sound waves into glass or wood, so I'd love to be able to blow up a printout and use it as a guideline.
Re: Software to visualize sound waves [message #98172 is a reply to message #98171] Sun, 29 December 2024 20:55 Go to previous messageGo to next message
Hi I see two ways to do this. First (as you probably figured) you have to get the sound into a PC. I use Windows so if you use some other brand it may be different. If the sample is in digital form (CD, streaming etc) and not analog I would use a program like Audacity to trim it to size. Displaying the result can be done in the same program...but you have all the menus etc on the screen at the same time. In my system I would do a screen capture and clean it up in a graphics program so that all you have left is the strip with the sound display. You could then size it to fit your needs. If the source is analog you will first have to "record" it into the PC to get the digital file. Many programs will do that. I suspect that there might be some software out there that would do exactly what you want but I don't know of any. Anyone out there with some ideas on what seems a very worthy project?
Re: Software to visualize sound waves [message #98195 is a reply to message #98172] Wed, 01 January 2025 17:57 Go to previous messageGo to next message
gofar99 wrote on Sun, 29 December 2024 20:55
It's a very sweet idea, leot55. You could use something like WavePad or Sonic Visualiser to create your artwork. Or, how do you feel about buying your gift, instead of making it yourself? I ask because Uncommon Goods has a seller that makes custom made song art. Check it out and see if it'll work for you.
https://www.uncommongoods.com/product/custom-song-wall-art/531760000002
Re: Software to visualize sound waves [message #98218 is a reply to message #98195] Thu, 02 January 2025 22:01 Go to previous messageGo to next message
Madison wrote on Wed, 01 January 2025 17:57
I'm never opposed to buying something rather than making it myself, but I'm quite miffed that someone else had the same idea. I wanted to giver my wife something unique, and I thought I had an original idea. She is such an amazing woman. She truly is my perfect mate for life. Now I'm not so sure about going with this idea for an anniversary gift.
Re: Software to visualize sound waves [message #98223 is a reply to message #98171] Fri, 03 January 2025 19:23 Go to previous messageGo to next message
It's a fabulous gift idea, Leo. I would melt if my husband gave me something like that. You should still go for it. If you want to do something slightly different than what's available commercially, you could use Friture to create a spectrum analyzer of the chorus, then craft something to represent that bit. I think your first idea is wonderful, though.
Re: Software to visualize sound waves [message #99343 is a reply to message #98171] Mon, 13 April 2026 00:42 Go to previous messageGo to next message
Clint is currently offline  Clint
I've had a similar experience where a couple contracted me to handle their anniversary sound production using their first dance song. I picked Audacity, powered the MP3, zoomed straight into the chorus, and exported a crisp black and white waveform, which is at 600 DPI. Worked on it over time and gave it to them. I can still recall the joy on their faces when they played it.
One thing that I like about Audacity is that it is free and can do this job perfectly without any issues. You just have to trim the chorus, play file, click on export as picture and then pick PNG. I don't need any plugins for that.
You can also scale the PNG to any size you desire using vectors. I can help you handle this if you need my services. Thank you.
Re: Software to visualize sound waves [message #99346 is a reply to message #99343] Tue, 14 April 2026 08:15 Go to previous messageGo to next message
One of my favorite things to do is to connect an oscilloscope to the left and right channels, and to display Lissajous patterns of the music.
Re: Software to visualize sound waves [message #99478 is a reply to message #99346] Thu, 04 June 2026 13:17 Go to previous messageGo to next message
Wayne Parham wrote on Tue, 14 April 2026 08:15
That is pretty cool, and I am imagining how nice it will come out.
I would want to know the kind of oscilloscope that you make use of? Also, what songs do you think gives the best Lissajous patterns?
Re: Software to visualize sound waves [message #99480 is a reply to message #99478] Thu, 04 June 2026 14:57 Go to previous message
My scope is a tried-and-true Tektronics 2230.  I've had it for years - decades - since the 1980s.  Can't believe how time files;  Seems like yesterday for me.
As for music content that's "fun to watch," the best stuff has bass notes that are shifted 90 degrees between left and right channels. Better when they shift between +/-90 degrees, cause that's a cool look.
One song like that is "Welcome to the Machine," by Pink Floyd.
Previous Topic: Should I blow the budget on getting expensive cables?
Next Topic: Is room treatment a must for bedroom producers?
Current Time: Sun Nov 01 02:41:03 CST 2026
