Home » Audio » Speaker » Screw Loose (Screws for a JBL 2226 woofer)
Screw Loose [message #98116] Thu, 12 December 2024 05:48 Go to next message
I'm looking for the screws that will fit a JBL 2226 woofer. Bought a big pack of 10-32 machine screws that have the correct threads but the head is too big to fit into the speaker frame.
Looked online. Seems the JBL uses something called a Fillister head screw. Please let me know if that isn't correct.
You can buy them in massive quantities that run $60 or $800 dollars or you can buy used ones on Ebay for $4 or $5 each.
Anyone know of a source for a small quantity of new ones?
Many thanks,
Barry
Re: Screw Loose [message #98117 is a reply to message #98116] Thu, 12 December 2024 09:30 Go to previous messageGo to next message
I use button head screws. Another option is Allen head screws, but I think button head screws are more attractive.
Re: Screw Loose [message #98118 is a reply to message #98117] Thu, 12 December 2024 12:18 Go to previous messageGo to next message
Excellent. Button head screws are ordered ...
Many thanks!
Re: Screw Loose [message #98127 is a reply to message #98116] Sat, 14 December 2024 20:12 Go to previous messageGo to next message
Hi Take one of the ones you have an put it in a drill and grind it down on a file.
Re: Screw Loose [message #99706 is a reply to message #98127] Tue, 18 August 2026 14:04 Go to previous message
George is currently offline  George
gofar99 wrote on Sat, 14 December 2024 20:12
That's extra stress when he can just order new screws that can get the job done. Don't you think so?
Previous Topic: Can speakers still compete?
Next Topic: Do you feel excited having tall DIY speakers than commercially made ones?
Current Time: Sun Nov 01 18:36:21 CST 2026
