Home » Audio » Measurement » Best music for testing speakers?
Re: Best music for testing speakers? [message #97912 is a reply to message #84678] Wed, 24 July 2024 23:00 Go to previous message
How serious are you about this experiment? If you want to get down into the nitty-gritty, measurable testing that's backed by science, then you should focus more on the testing equipment and your room's acoustics, rather than the genre of music that you're testing. On the other hand, if you're just looking to get the most out of your speakers in a simple, but actionable way, then I suggest using the music that you most enjoy during the testing process, since that's what you're dialed into.
Previous Topic: The best apps to measure noise levels
Next Topic: Turntable Cartridge Measurements
Current Time: Fri Nov 06 00:55:01 CST 2026
