Home » Audio » Thermionic Emissions » Say John 42
PS options [message #9789 is a reply to message #9770] Fri, 18 August 2006 21:24 Go to previous message
Hey_Hey!!!,
Another option would be to go CLCLC and drop the inductance of the 'L' stages. Say to 2 Hy each, experiment with capacitance values and see where the final ripple comes equal or perhaps just less than a single stage goes.
Keep in mind that it is not likely that the 'shape' of the resulting ripple voltage is also going to be different with a multi-stage filter compared to a single.
It is my opinion that keeping the DCR low is a good idea. It isn't possible to do it 'all else kept the same' so it shouldn't follow that PS performance is tied to a the value of a single parameter. Either way, examine the performance of the filter as component values change around a reasonable centre, or preliminary value.
cheers,
Douglas
Previous Topic: Tube amp humm, Power conditioner?
Next Topic: Ei Tube Factory
Current Time: Sun Nov 15 14:17:53 CST 2026
