Home » Sponsored » Pi Speakers » Retrofitting Altec 612 cabinet for a 4pi build (Talk me into or out of this idea!)
Retrofitting Altec 612 cabinet for a 4pi build [message #97858] Fri, 12 July 2024 10:30 Go to next message
lowtrail is currently offline  lowtrail
I have an empty 6cu. ft. cabinet I want to do something with. I'm curious if the 4pi might work in this enclosure using a combination of volume reduction strategies.
You can read the full backstory on this thread on DIY Audio.
I was encouraged to ask the group here for advice.
Some specific questions I have:
1. Has anyone had success building 4pi in larger enclosures? If so, how was the xo modified? I have no experience with xo design.
2. If I were to subdivide my 6cu ft. enclosure (woofer chamber and horn chamber) to give the woofer the same volume as the standard 4pi build, would the xo need modifications? Port location would presumably change.
Looking forward to an education Smile I'm very new to all of this.
Re: Retrofitting Altec 612 cabinet for a 4pi build [message #97860 is a reply to message #97858] Fri, 12 July 2024 15:15 Go to previous messageGo to next message
I wouldn't change the dimensions of the cabinet for these reasons (from the Pi Speakers FAQ):
I realize you are talking about reducing the internal volume by partitioning, but I did want to comment on the subject of larger cabinet volume, nonetheless. One can gain bass extension with a larger cabinet, provided internal standing waves in the midrange are mitigated. But what I suggest instead is to use flanking subs, which serve three purposes:
1. They provide bass extension
2. They provide baffle step mitigation
3. They provide mitigation of SBIR and higher-frequency room modes.
More on that:
Re: Retrofitting Altec 612 cabinet for a 4pi build [message #97874 is a reply to message #97860] Wed, 17 July 2024 09:09 Go to previous messageGo to next message
Thanks for the helpful links, Wayne.
I will likely take the Econowave approach and use this for a platform for experimentation and learning.
Re: Retrofitting Altec 612 cabinet for a 4pi build [message #97875 is a reply to message #97874] Wed, 17 July 2024 14:14 Go to previous message
There you go! That's a fantastic idea!
Evan Flavell (Zilch) would love that cabinet. He'd be proud!
Previous Topic: 2pi towers
Next Topic: Help with value of 4 Pi kit/speaker
Current Time: Fri Nov 13 05:48:53 CST 2026
