Home » Sponsored » Pi Speakers » Pi midhorn with AE TD10m (Compatibility)
Pi midhorn with AE TD10m [message #97816] Mon, 01 July 2024 05:02 Go to previous message
SpinMonster is currently offline  SpinMonster
I have a pair of the AE TD10m and am looking for input on its compatibility with the 24" midhorn flat packs.
The TD10m has a low qts. Is there anything in the specs that would make it a poor candidate for use in the midhorn covering 300 to 1400hz or near that range? 250 to 1200?
Thank you for your input.
Edit: The system will be active. I have a DBX venu360
I also already own the radian 475 beryllium compression driver.
Parts are expensive and I'd like to re-use what I have.
I'm old and don't care about big spl
I'm after the imaging of the corner horn
Previous Topic: Two PI depth adjustment
Next Topic: 2pi towers
Current Time: Sun Nov 08 01:21:44 CST 2026
