Home » Sponsored » Pi Speakers » Two PI depth adjustment
Re: Two PI depth adjustment [message #97813 is a reply to message #97812] Sun, 30 June 2024 17:47 Go to previous messageGo to previous message
Tronographic is currently offline  Tronographic
Thanks Wayne...
I used this to figure out how much to increase the depth to compensate for the thicker panels, since I already had the height and width locked in.
https://www.the12volt.com/caraudio/boxcalcs.asp#rec
Increasing the depth about a 1/2" to 15-1/2" got the volume pretty close to the same as the stock dimensions
So I ended up with about 10-5/8" deep, I had to fudge the volume of the braces and cleats... And my width actually ended up at 14-15/16" after it was all glued up. So I figured better to round up than round down...
Also, if I decide to roundover the port front say with a 1/2" roundover for aesthetics, do I measure the port length from right behind the rounded portion? Basically the straight section of the port?
Thanks!
Previous Topic: Barkyard BBQ Drive-in Theater Speakers....
Next Topic: Pi midhorn with AE TD10m
Current Time: Sun Nov 08 02:07:54 CST 2026
